Electra Glides to avoid?
I'd avoid the 2003 if it hasn't been gone through.
My good buddy bought one new and the engine grenaded at 21K miles because of the cam chain tensioners falling apart.
The early TC motors were all subject to that possibility but 2003 they made a lot of bikes because everyone wanted a 100th anniversary bike.
It was also the first years for the cast crank vs the '99-'02 with the forged lower end and Timken tapered main bearing.
I had a 2000 for 20 years/200,000 miles,did new tensioners and cam bearings at 40K then at 100K swapped to gear drive cams.
The lower end on those early TC bikes are good candidates for the GD swap because of the better lower end.
I'd also shy away from a 2017 first year M8 if the oil pump and fluid transfer issue hasn't been addressed,I have a 2019 and it had the transfer issue but was solved with the vent fix.
The late TC bikes with the 103 and a good choice and coming down in price with the M8 being out 8 years now.
I agree, except on two points...
I wouldn't avoid an early (spring tensioner) Twin Cam engine ('99-'06). I would just adjust my purchase offer if they have no proof (receipts) that the spring cam tensioners were updated. Any older Twin Cam, especially over 20K miles, IMHO, is in immediate need to have the tensioners upgraded.. Once those tensioners are updated, if it is a well maintained bike in good condition, you can have a really good, reliable bike.
Also, I don't think the cast cranks started until '05 or '06...
As I recall:
'99-'02 had hot forged cranks and lefty Timken bearing.
'03-'05 (or '06) they removed the lefty Timken bearing, but used cold forged cranks
'05 (or '06) was the first year for cast cranks....
OP...
All years have an issue or two... luckily there is nothing out there that does not have a fix for it available....
I've always felt it is best to buy the most recent year bike your budget will allow.... but when looking at similar bikes (year/mileage) maintenance history and condition are more important than several years or a bit more miles.
The following 3 users liked this post by hattitude:
What Japanese "cruiser" has an air cooled v-twin and hard bags? All the jap bikes I see besides ones with tiny engines have a giant radiator in the front and gawdy styling.
Didn’t see it mentioned unless I overlooked it, up to 01 was MM injection if EFI, 02 and after was Delphi which was easier to work with. Carbs were offered through 2006. 2005’s had what was called valve-itis with the seals. IIRC, the 05’s still used a 38 amp rotor but that could swapped out. IMO, 2002 and 2006 were good TC88 years. Then came all the changes others mentioned like TC96 in 07, 6 gallon and cush drive in 08, frame in 09, etc.
07UltraGuy (04-25-2024)
I wouldn’t trade my bike for a newer version either, but if I were buying TODAY, I’d be looking at and comparing 2013’s & 2014’s.
kombiguy (04-25-2024)
Received 4,419 Likes
