Touring steering stabilizer
Old 04-02-2007, 11:26 AM
TFR's Avatar
TFR
TFR is offline
Default Touring steering stabilizer
Does anyone make a steering stabilizer for the touring bikes? Have an 07 SG that I would like to install a stabilizer for highway riding.
Had one on my previous metric bike and it makes a large difference on wind wobble.
Any help would be appreciated
Old 04-02-2007, 11:50 AM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Default RE: Touring steering stabilizer
True-track or This one?(butthe latterlooks like it is only for dyna, softails,and sporties)[>:].
Old 04-02-2007, 12:05 PM
HogBoy's Avatar
HogBoy
HogBoy is offline
There's True Track and another one--Str8Rider or something like that. Do a search here and you'll come up with it.
Old 04-02-2007, 12:15 PM
Eyespy's Avatar
Eyespy
Eyespy is offline
Location: Southern California High Desert, here and there....
I've got the RideStr8 on a 2000 FLHTPI, which did improve the rear wheel steering by adding a third stabilizing link to the transmission housing aft of the swingarm pivot. However, I am not aware of any steering stabilizers for touring HDs. No easy way to mount a rotary style like the Scotts or GPR, and because of the fork beer cans, no easy way to mount a shaft style damper. However, with some ingenuity and machining skills, a mouting bracket system could be engineered to affix to a fork tube above the lower tripple clamp. Wouldn't mind one myself.
Old 04-02-2007, 05:26 PM
zubaugh's Avatar
zubaugh
zubaugh is offline
I've added a True-Track.
I also replaced the oil in my front shocks with SE HD and that has made a big time difference.
Old 09-03-2008, 11:49 PM
TRMRC's Avatar
TRMRC
TRMRC is offline
Cool
V-Twin Mfg has a couple that may work ( I am going to call them), they have 41mm clamps for the fork tube, and 1 inch clamps for the highway bar. If you have an air baffle under your trees, I believe that has to come off & you cant have lower fairings I understand. I also have an email to a a trike company, they use them on their FLH trikes.. I will keep you posted. I figure this & a rear stabilizer on my 06 SG..she should be tight.
Old 09-04-2008, 12:14 AM
Emporers New Clothes's Avatar
Emporers New Clothes is offline
He said STEERING stabilizer not rear stabilizer.
and to answer your question there is only one stabilizer out that I am aware of that actually will help with steering and Alloy Art makes a front stabilizer
http://www.alloyart.com/products/trilink.html
this is said to help improve front end high speed handling.
Old 09-04-2008, 12:54 AM
Comfortably Numb's Avatar
Comfortably Numb
Comfortably Numb is offline
Doesn't he mean a "steering DAMPER" like those on sportbikes?
That would be NONE of the above suggestions.
How 'bout seeing if Ohlins makes one. I know they're out there for Harleys.
CN
Old 09-04-2008, 07:34 AM
TRMRC's Avatar
TRMRC
TRMRC is offline
Wink
[QUOTE=Comfortably Numb;3824975]Doesn't he mean a "steering DAMPER" like those on sportbikes?
My info is about a steering damper(s). I just didn't use the words.
Great Pic by the way Comfortably Numb.
Old 09-04-2008, 07:38 AM
skydoc's Avatar
skydoc
skydoc is offline
Quick Reply: Touring steering stabilizer
