Need Help. Missing gears after broken shifter shaft 883
Old 03-09-2014, 09:58 PM
RustyRatRX's Avatar
RustyRatRX
RustyRatRX is offline
Stage III
Default Need Help. Missing gears after broken shifter shaft 883
Hi, I am new to these forums so forgive me if this is in the wrong place.
I recently bought a 2013 Iron 883 for a low price because it had been laid down and the shifter shaft was broken off. I am new to Harleys, well.. motorcycles for that matter. I am a car guy though so i figured some of the same mechanics might apply. When changing the shaft I knew that I had to lock the sprockets together to get the gears and chain off.. What I did not realize was that the clutch nut was reverse threaded. I think I may have cranked it to the left too hard and caused something to slip (it felt like it broke loose, but actually turned the whole clutch assembly). I eventually figured out the threading and got it off, changed the shifter shaft and reassembled.. but now I have the problem of only getting 2-3 gears. Could this have something to do with the slip i felt when turning the clutch nut the wrong way? If so, how do I go about fixing this problem. Any help is greatly appreciated! Its getting nice and warm so id like to take it out asap.
Old 03-10-2014, 10:03 AM
corliss@bakerdrivetrain.com's Avatar
corliss@bakerdrivetrain.com is offline
Received 1,856 Likes on 1,287 Posts
When you say shifter shaft do you mean the shaft exactly which shaft are you referring to.
Old 03-10-2014, 12:15 PM
RustyRatRX's Avatar
RustyRatRX
Stage III
The shaft that goes directly into the transmission.. the shaft that the shift lever (foot control) is connected to it. I can take pictures when I get home if it helps
Old 03-11-2014, 09:35 PM
RustyRatRX's Avatar
RustyRatRX
Stage III
Anyone? Ive attached a picture of a shifter shaft to clarify. (not my bike, but it looks exactly the same)
Old 03-12-2014, 09:21 AM
heybaylor's Avatar
heybaylor
heybaylor is offline
Just a guess, but when the bike fell down and broke the shifter shaft , it could have bent/broke the "pusher".
that is the part that pushes/pulls the shifter drum, also the pins on the drum may be bent
Fblo1690
EVO
10-21-2017 03:48 PM
DaveNBPT
2014-2023 Touring Models
17
04-18-2016 09:51 PM
emerican19
11-24-2012 10:02 PM
namato1
07-28-2011 07:58 AM
More_Beer
09-19-2008 02:01 PM
Quick Reply: Need Help. Missing gears after broken shifter shaft 883
