Primary Drive Locking tool
Old 03-22-2007, 01:27 PM
rob_will's Avatar
rob_will
rob_will is offline
Default Primary Drive Locking tool
I am looking to buy one, does any one know where I can buy one, other than the HD one? I just don't feel like spending 4 times what the tool is worth.
Old 03-22-2007, 01:28 PM
Psycho's Avatar
Psycho
Psycho is offline
Default RE: Primary Drive Locking tool
If you're working on an 06', then that is the wrong tool you've got pictured there.
Old 03-22-2007, 01:32 PM
rob_will's Avatar
rob_will
rob_will is offline
great!!! do you know what it is supposed to look like?
Psycho's Avatar
Psycho
Psycho is offline
I made one out of a jack handle.
Required tools are a torch, a big hammer, and a good grinder.
Old 03-22-2007, 01:45 PM
rob_will's Avatar
rob_will
rob_will is offline
I'm trying to change my mid controls to forwards, but in the directionsit says to use one. does anyone know the correct tool for it?
Old 03-22-2007, 04:12 PM
Psycho's Avatar
Psycho
Psycho is offline
The correct tool part number is in the service manual on page 6-10, along with an illustration of how it is to be used.
You need a service manual if you are going to be disassembling your bike to this extent.
The part number for the locking tool is "HD-47977"
Old 03-22-2007, 05:25 PM
mtnlvr's Avatar
mtnlvr
mtnlvr is offline
I used a piece of scrap steel bar....1/8-1/4" thick....a little wider than the main sprocket....had to play around with the length....also notched one end to clear something on the clutch basket.
Simple...yet effective.
Old 03-22-2007, 07:13 PM
ROADTRAIN's Avatar
ROADTRAIN
ROADTRAIN is offline
use a thick shop rag or towel and jamb it between the chain and sprocket. this is the method I've been using for years.
Old 03-22-2007, 08:39 PM
rob_will's Avatar
rob_will
rob_will is offline
just came back from the stealer...38.95 brand new. I didn't buy it but from the posts it should be fairly easy to hand make
Old 03-22-2007, 09:56 PM
jmbear328's Avatar
jmbear328
jmbear328 is offline
I just saw several of the ones for the 06 Dynas on ebay.
John
Quick Reply: Primary Drive Locking tool
