1/4 mile times
Old 03-18-2007, 06:32 PM
Blue HD's Avatar
Blue HD
Blue HD is offline
Default 1/4 mile times
Does anyone have an 1/4 mile times and traps for an 883-1200 conversion Sporty? I assume with the SE AC, jetted carbs and exhaust, etc (ie- the usual suspects when doing this conversion it would seem) and the lower gearing in the 883 vs the stock 1200, that it scoots pretty well...
But does anyone have any times documented, or has their been any articles in any rags, etc?
Thanks in advance!
Old 03-18-2007, 07:30 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Default RE: 1/4 mile times
The slightly 'lower' gearing of the 883 will help more on 1/8th mile runs than a full quarter mile.
You will wind through each gear slightly quicker, but you also have to shift quicker. Years ago there were a number of articles dealing with the gearing in high performance drag cars. Most of these tests involved a car that made a pass with a certain rearend gear ratio (say a 4.10), and then a pass with a ratio in the 3.55 range. The results were very close, much closer at the end of the quarter mile than many would suspect.
The ideal situation is to have your bike (or car) geared so it will cross the quarter mile mark at the top end of it's power band in it's top gear (without shifting into 'overdrive' which is less than a 1 to 1 ratio).
Anyway, LoL, to answer your question, it would depend on the "883 to 1200" conversion that is done to the bike.
There is more of a difference between the 'stock' 2004+ 1200 engines than just additional displacement.
The 883 has a bore and stroke of 3.0"x3.8", while the 1200 is 3.5"x3.8", but the 1200 also has lighter piston and rods, and the useable power range has been increased to 6,000 RPM.
The 883 runs a 8.9-1 compression and can run on 87 octane fuel, while the 1200 has a compression ratio of 9.7-1 and requires 91+ octane fuel.
The 1200 also uses high flow cylinder heads from the Buell XB line, and cams from the 1200 Sport.
Factory horsepower and torque figures for the 883 are 53 HP at 6,000 RPM, and 51 LB-FT at 4,300 RPM.
Factory horsepower and torque figures for the 1200 are 70 HP at 6,000, and 79 LB-FT at a lower 3,500 RPM.
The extra displacement, different rods, heads, and cams all need to be replaced in the 883 to do a "true" 883 to 1200 conversion. Another thing you might have to consider during a conversion is raising the rev-limiter on 883 bikes. We hooked some gauges up to my 2005 1200C and the rev-limiter kicked in right below 6,000 RPM. On a friends 883 it kicked in just over 5,500 RPM.
Stage 1 dyno tuned 1200 bikes usually see rear wheel horsepower figures in the 70 range, although I have seen higher figures where everything came together just right.
Quarter mile times for a well tuned "Stage 1" 2004+ 1200 vary, depending on the rider, ideal conditions, etc., but they should be somewhere in the very low 13 second range for the most part.
Old 03-18-2007, 08:12 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
GothMetalGuitarist is offline
Great post OFG.
Old 03-18-2007, 11:37 PM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
Not sure about anything older than the 04 and up 883s but their rev limiter is set at 6000 rpm.
Most of the 1200 and 1250 kits I have seen raise the compression ratio to 10:1 so after the conversion 91+ octane will be mandatory. My 883 right now can't stand 87 octane and will diesel when i use it. It likes 89 a lot better.
Old 03-19-2007, 01:29 PM
Blue HD's Avatar
Blue HD
Blue HD is offline
Thanks, OFG, for the great post. Good info. I know some of the kits include the heads, cams, rods, etc. And I figure with the SE AC and exhaust, that's only gonna help matters.
I used to drag race cars (Mustangs mostly) back in the day, but launching bikes is a whole 'nother deal. I was just curious about what kind of improvements folks were seeing, etc.
The parts catalog also had the SE ignition module which was said to help peak power and raise the redline, etc...
HDF Tech
Engine Mechanical Topics
01-19-2024 04:40 PM
Rynb15
11-11-2019 08:49 PM
SteveFlintstone
11-01-2011 11:21 AM
no regrets
05-21-2008 04:16 PM
chrism84
11-26-2006 10:04 PM
Quick Reply: 1/4 mile times
