Just bought 2014 HD Limited. Love it. Need help
Old 12-28-2013, 06:58 PM
lmferris's Avatar
lmferris
lmferris is offline
Default Just bought 2014 HD Limited. Love it. Need help
With Nav background color. Seems to switch from a nice green background to black on its own. Owners manual no help. Anyone that can help would be appreciated.
Old 12-28-2013, 07:15 PM
DGRF250's Avatar
DGRF250
DGRF250 is offline
Did u download and install update ?
Old 12-28-2013, 07:22 PM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Does it do it at dusk?
My Garmin self adjusts for night time use at dusk and goes from green to grays
Congrats by the way!
Old 12-28-2013, 07:33 PM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
I also was interested when it does it, that unit has an auto dimming feature in bright/low light conditions. I would also suggest you get the latest software download from your dealer. Mine only took a few minutes and it took out any quirks mine had if it is that instead.
Old 12-28-2013, 08:22 PM
Ghostrider1967's Avatar
Ghostrider1967
Ghostrider1967 is offline
Congrats on the new bike. You could check 1st.,to see if you have the lastest version which is 1.17.1.1 on the bike. There were some issues with the older version? You can go to HD website and download the newest version. Follow the instructions on the website. Download it to a flashdrive and plug it into your usb port on the bike. I have my backround color set to gray from day one and it's been fine. The infotainment system takes some getting use to. I've spent hours with mine just getting use to all the features. Be sure to hook your battery tender up in the garage, while getting familiar with it all. Hope this helps?
Old 12-28-2013, 08:41 PM
offthewall's Avatar
offthewall
offthewall is offline
Probably switching from day to night mode. You can adjust that in the display settings.
Old 12-28-2013, 09:50 PM
lmferris's Avatar
lmferris
lmferris is offline
Default Thank you all. Big help. Will get the update
Thank you
Old 12-28-2013, 10:17 PM
harleyjth's Avatar
harleyjth
harleyjth is offline
You can get the latest software updates directly from HD here. No need to go to dealer.
http://www.harley-davidson.com/en_US...downloads.html
jt
Old 12-30-2013, 01:54 PM
nchogfan's Avatar
nchogfan
nchogfan is offline
Is it the background color or the map color? Mine changes map colors like that and I think it does it at the city limits, when you go in and out.
Old 12-30-2013, 02:10 PM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
Just did the update from 1.6 to 1.7 on mine, fairly painless. Only problem was after the update the screen locked up when I was changing one of the settings in the set up menu, I turned off the ignition for a minute or so and everything went back on. Does anyone know what this update does (other than lock up the screen, LOL)?
sportglide
02-07-2023 08:27 PM
billablehours
Audio Systems
11-13-2016 12:18 PM
Kugie's HOG
08-27-2014 09:11 PM
ricklbf74
01-08-2012 05:10 PM
shootdr
08-04-2008 04:37 PM
Quick Reply: Just bought 2014 HD Limited. Love it. Need help
