2014 103 cams
Old 11-29-2013, 06:25 PM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
Default 2014 103 cams
So the cams are different in the 14 103's. Anybody know what cam is in there? The hog mag just says "new cam" and doesn't say what cam is used.
Old 11-29-2013, 06:29 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,364 Likes on 2,619 Posts
Well, its a new cam, so thats what cam it is.
Here's some information about how its different.
Old 11-29-2013, 06:38 PM
Webo's Avatar
Webo
Webo is offline
They are similar to the SE255 but they are NOT the SE255..lol... If you look at the specs for each that is the cam they resemble.
Old 11-29-2013, 09:42 PM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
so do the 14's lope at idle?
Old 11-29-2013, 09:46 PM
Webo's Avatar
Webo
Webo is offline
No they don't really lope like a big duration cam but they do run good. This was the first HD I bought that I didn't think it needed a stage one kit day one just to increase performance. That said I did the stage one because it was to dang quiet...lol
Old 11-29-2013, 10:20 PM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
I want it to sound like it has a cam, but don't want too much lift.
Old 11-29-2013, 10:37 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
Get some 204's or 211's will really cut up and both are low on lift at .508 lift. The 211 would probably be little much without added compression. I know of a set of 204's in a SGS and it dynoed 94 hp. and 114 torque with true duals. It was in 40's and 23% humidity.
The stock cam sounds very similar to the 255 if you put a 2 in 1 or true duals on.
Old 11-30-2013, 01:18 AM
HDSAE60's Avatar
HDSAE60
HDSAE60 is offline
I'm thinking about the 204's with a PV from fuelmoto. I don't like the crank vapors going into the breather, so I vented into the atmosphere and may be limited to a K&N filter that will fit in the stock backing plate.
Old 11-30-2013, 07:00 AM
xhere's Avatar
xhere
xhere is offline
I installed the 204's at around 800 miles on my 14 sgs, what a difference! Great idle and pulls hard...I don't think you will be disappointed.
Randy L. Beckner
03-30-2019 07:24 PM
brawner11
03-27-2016 10:54 PM
jrdfatboy
04-06-2014 09:12 AM
dirtpan
Exhaust System Topics
10-31-2007 11:27 AM
cwilks
04-14-2007 11:36 AM
Quick Reply: 2014 103 cams
