FXST to Fatboy front end questions??
Old 10-10-2013, 08:41 PM
dsonnenberg's Avatar
dsonnenberg
dsonnenberg is offline
Default FXST to Fatboy front end questions??
Looking for help on changing my fxst frontend to a fatboy front end. Ultimately I want the fatter look of a fatboy/heritage with a 23" wheel. What do I all need to change and/or what can reuse off my current front end. Im not concerned with the wheel aspect yet as I will run my current 21. I just wanna start with putting the fatboy front end on first. do I need to change the triple trees? do I need to change the forks? would the fatboy lowers fit on my current forks... ect. You guys know more then I so let me know please? also if you know anyone who is selling these items. thx
Old 10-11-2013, 09:13 AM
Shakey Softail's Avatar
Shakey Softail
Shakey Softail is offline
the different is triple trees, fork sliders, headlight, tin, fork tubes are 2 inch short than now no rake 0 degrees and cow bells the heritage and deluxe front end is the same minus the running lights
Old 10-13-2013, 11:51 AM
dsonnenberg
thanks for the response shakey. Do you know if I can directly replace a fxst triple tree with a fatboy, is the neck bearing the same size?
Old 10-13-2013, 06:53 PM
Shakey Softail
No problem all harley's necks are the same but sportsters change in years all are 1 inch necks all the same. You can do a direct swap with no problem if your bike has a lot of miles replace the neck bearings and races for insurance
Old 10-13-2013, 07:18 PM
dsonnenberg
Right on, thx again, now I just need to find a fatboy front end for a decent price.
Old 10-13-2013, 11:38 PM
jm35ny's Avatar
jm35ny
jm35ny is offline
I always thought the frame must be different cause the fxst front end looks way more raked out than the fatboy
Old 10-14-2013, 09:18 AM
Shakey Softail
The rake is in the trees from factory 2 degrees the frame is the same
Old 10-14-2013, 09:46 AM
jm35ny's Avatar
jm35ny
jm35ny is offline
Good stuff. I've learned a ton here!
Old 10-14-2013, 01:18 PM
dsonnenberg
Yes lots of good stuff here, thx to Shakey! I have found the fatboy lowers and fork tins I now need to find the fatboy triple trees and forks. Lets say I was going to use my fxst forks that I now know are 2" longer then a fatboy, how do you think that would look? the front end I think would stick up high wouldn't it?
Old 10-14-2013, 05:37 PM
Shakey Softail
You could use them but the looks would be a personal thing meaning some like others don't have seen some one did it to me was out of place fork tubes are around 200 a piece but you might find a complete front end on ebay or craigslist or even maybe on here sell yours complete or trade
Quick Reply: FXST to Fatboy front end questions??
