2014 limited cb mic question
Old 09-21-2013, 07:58 PM
rmc115's Avatar
rmc115
rmc115 is offline
Default 2014 limited cb mic question/ answered
Picked up my 14 today and while learning the radio details i plugged in my cb mic and do not get a change when keying mic. lights up like it should when i press ptt. worked fine on my 12. manual shows nothing about a handheld, but catalog does not say it wont work with 14's. any try it or willing to try theirs? Mike
Old 09-21-2013, 08:11 PM
harleydude-fla's Avatar
harleydude-fla
harleydude-fla is offline
I've tried my hand held mic. on my '14 Limited, same as yours, does not play. I checked the wiring diagram in the manual and the headset connectors no longer have a "Push to Talk" wiring.
I guess I'll have a Mic. to sell on eBay.
Old 09-21-2013, 08:23 PM
rmc115's Avatar
rmc115
rmc115 is offline
Thanks, that's what i was afraid of. I dont wear a lid most of the time and use it frequently on HOG chapter rides. That sucks. wonder if you could hitt the ptt button and talk into mic?
Old 09-21-2013, 09:40 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
Trade you a new 1/2 helmet headset for it..
Mark
Old 09-21-2013, 10:06 PM
rmc115's Avatar
rmc115
rmc115 is offline
Page 71 of the regular manual (not boom manual) says " a special hand held mic can be used available through your harley dealer". wonder if a new one works? Mike
Old 09-21-2013, 10:12 PM
Hammz's Avatar
Hammz
Hammz is online now
Default Hand Mic on '14 models
The hand mic will work BUT, you have to key the hand mic AND the the PTT switch on the right handlebar both at the same time.
The hand mic could probably be rewired internally so you don't need to press its' PTT, but then it won't work for older models. In any case, the right handlebar PTT must be used to put CB into transmit mode.
Old 09-22-2013, 07:58 AM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
I'm having the same problem with the handheld mic when I try to use it with the CB, however it works with the Intercom and it also works with Voice Recognition. I'm wondering if a software update would cure the problem.
Old 09-22-2013, 03:05 PM
rmc115's Avatar
rmc115
rmc115 is offline
I just tried a buddies new mic and same issue and since we had 2 bikes tried using the ptt button and talking, didn't work. i noticed my radio software is 1.16.9 which has a update available 1.17, trying that tonight. Mike
Old 09-23-2013, 10:53 AM
rmc115's Avatar
rmc115
rmc115 is offline
updated s/w to 1.17, no help. called dealer and they are checking wit HD. If anyone has a 14 limited that the handset works speak up. mike
Old 09-23-2013, 11:42 AM
PIGGI's Avatar
PIGGI
PIGGI is offline
Silly Question, are you sure you have the CB option? It's not standard issue anymore, extra cost option.
Quick Reply: 2014 limited cb mic question
