Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
2014 Limited Hitch and Wiring
Old 09-25-2013, 08:20 AM
madmustang4's Avatar
madmustang4
madmustang4 is offline
latest update.
I'm pretty sure i can get the hitch mounted to the bike (with 2 of the 3 holes) but, Bushtec wiring harness will not connect to the 2014 HD wiring harness under the seat.
So i'm kinda dead in the water until bushtec can come up with a new one.
Old 10-02-2013, 06:41 PM
blairsimister's Avatar
blairsimister
blairsimister is offline
5th Gear
Ok, when a wire hardness is available please post
Thanks!
Blair
Old 10-02-2013, 11:08 PM
sdwold's Avatar
sdwold
sdwold is offline
From my perspective the answer is NO! Harley changed the upper frame bolts on the 2014 and they will not work with existing hitches
Old 10-03-2013, 08:11 AM
madmustang4
I have successfully mounted my Bushtec version 1 pin hitch to my 2014 ltd.
It fits except that i can only connect 2 of the 3 side bracket holes to the bike. If you look at my pictures in my prior post you can see which of the 2 holes attached. In a call to Bushtec they told me that they do installs where only 2 screws are attached to the bike.
Still dont have a wiring harness so still not able to pull the trailer. Was told that Bushtec would have a new wiring harness available by mid October. Not sure if they're still on track for that date or not. I actually took my old wiring harness to my local automotive electrical guru guys and asked them if they could modify to adapt to 2014. They said no.
1) they would need schematics from Harley
2) They would need to get the plastic male female connectors and that would cost a fortune cuz you cant just buy the connectors. you would have to buy an entire wiring harness from harley and that could run in the hundreds or more
3) The can bus thing was still unclear to me as to whether that would be an issue or not
Old 10-03-2013, 08:22 AM
white83's Avatar
white83
white83 is offline
I have contacted all the vendors I could find on the net and they all said that they do not fit the 14' Limited. They all said around Spring they have the hitches ready for sell.
Old 10-07-2013, 03:26 PM
madmustang4
well, nothing new from Bushtec on when they will have a new wiring harness available for the 2014 Ultra limited.
I'm going stir crazy and need to go on a ride so gonna have to do it the old way, with T-Bags. Going up to Wisconsin and Door county this week as its supposed to be great weather for the next several days.
Old 10-11-2013, 08:24 PM
rmc115's Avatar
rmc115
rmc115 is offline
you can buy every piece of electrical connectors from harley, electrical diagrams are in back of service manual. if the trailer has LED lights it won't be a big deal. Mike
Old 10-31-2013, 03:46 PM
lewis/ec's Avatar
lewis/ec
lewis/ec is offline
Stage IV
This is Lewis from Electrical Connection...we build the wiring and electronics for Bushtec.
The 2014 bikes are now all CanBus. They have combined turn signal and brake lights directly from the BCM (body control module). In order to have separate functions, we designed and are building a device that looks at the state the bike's lights are in and creates separate outputs for brake, left turn, right turn, and run. But in such a way it does not cause a CanBus fault.
If your trailer is a 4 wire, all you need is the new sub-harness and the isolator. If your trailer is a 5 wire, you need the new CanBus module.
The pinouts on the 6 pin Molex plug are different on the 2014 bikes. We have a new harness as well.
If you have any questions, or need some clarification, drop me a line. Happy to answer a question.
Lewis
Old 11-02-2013, 11:39 AM
white83's Avatar
white83
white83 is offline
What will the total cost be to setup my 1993 Turbo trailer with the new 2014 Limited motorcycle? I looked on you website and couldn't find the kit you talked about.
Old 12-08-2013, 08:53 PM
rmc115's Avatar
rmc115
rmc115 is offline
a 14 hitch is now out here, http://www.openroadoutfitters.com/
Quick Reply: 2014 Limited Hitch and Wiring
