New HO 103 Touring, cam specs.
Been reading a lot of posts on the new touring bikes. According to Harley the compression has been increased a bit and there is a new slightly higher lift ,longer duration cam in the new motors. Has anyone seen the specs on this cam , either in a new SE brochure under stock cam comparison or from some technical information posted somewhere in regards to actual numbers , lift , overlap etc for this particular improvement. Thanks.
There are some written information next to the chart in the above image. There is much more technical information in a slide presentation that one of the forum member posted. I believe that has since taken down being that it was copyright material.
[QUOTE=psuchit;11684040]There are some written information next to the chart in the above image. There is much more technical information in a slide presentation that one of the forum member posted. I believe that has since taken down being that it was copyright material.[/
I did see that , thanks , the lift info is not there , will continue digging for it . sometimes getting info for Harley is like looking for a needle in a haystack.
I can see all that , thanks, obviously it contributes to torque values, it tells me that also. What I was specifically looking for is a no. indicating the LIFT . Do you by any chance have any info regarding that particular spec.
Very interesting cam info, after riding a 14 Street Glide I knew there had to be something besides a .1 increase in compression and air box. The bike pulled well in all gears with no flat spots and corked exhaust. Will probably wait for 15 when the new Road Glide comes out, not quite 40,000 on my 2011 Road Glide Ultra.
