One Baffle - with active exhaust
Old 08-09-2013, 03:35 AM
Cogs's Avatar
Cogs
Cogs is offline
3rd Gear
Default One Baffle - with active exhaust
Advice please
I have a 2011 Wide Glide with Vance & Hines Slip ons. Tommy gun with this active exhaust
I was thinking.. if I took out the baffle on the active exhaust (the top one) surely the active exhaust will provide the back pressure? I took it out it sounds ok , one baffle in one baffle out. ?
Any views would be great
Many thanks
Cogs
Old 08-09-2013, 04:47 AM
Foxster's Avatar
Foxster
Foxster is offline
Most people just jam the active exhaust valve open.
I doubt it will give much in the way of back pressure anyway because its usually open at speed i.e. when you want the back pressure.
Old 08-09-2013, 11:39 AM
ghira75's Avatar
ghira75
ghira75 is offline
I bought a device from kess tech that with a switch I can select between "normal" operation of active exhaust or "always open". I tested both ways several time, the active exhaust does work at speed under acceleration closing the valve at some speed or rev intervals. It is very obvious the lack of power with the valve closed. Therefore it doesn't provide backpressure, it just chokes the fumes on the way out reducing power. I'd suggest you try to find out...
fat_tony
04-04-2015 10:46 AM
Pitbull33
10-05-2013 01:50 PM
AU_Bob
Exhaust System Topics
04-05-2013 11:05 AM
mark0763
06-09-2010 01:39 PM
tjsnoop
01-23-2010 08:33 AM
Quick Reply: One Baffle - with active exhaust
