Breakout reflectors
Old 07-26-2013, 08:03 AM
P_RsBO's Avatar
P_RsBO
P_RsBO is offline
Default Breakout reflectors
For those of you that have removed the reflectors, did you also removed the one on the rear fender? If so, did you leave the plate on or is there a way to remove the plate as well? Thanks.
Old 07-26-2013, 11:41 AM
parttime379's Avatar
parttime379
parttime379 is offline
if u look closely the bracket has a 'push in' type catch so u can remove it too under the fender
Old 07-26-2013, 12:53 PM
crawlgsx's Avatar
crawlgsx
crawlgsx is offline
Can you explain that more?
I would love to remove that plate/reflector but I had read back a while ago it required removing the rear fender.
Old 07-26-2013, 01:14 PM
Harley_Charley's Avatar
Harley_Charley
Harley_Charley is offline
It can be removed its just a PITA. Took me about 20 mins but it came out. I carefully used a flathead screwdriver and a hook tool to gently rock the reflector loose and pull it out. Note: it's held under the metal bracket with 3M tape so be patient. As for the bracket on the fender, I left it alone since my only goal was to remove the reflector. Be careful not to crack your paint by prying to hard. Oh, didn't remove the fender either.
Old 07-27-2013, 09:26 AM
P_RsBO's Avatar
P_RsBO
P_RsBO is offline
It looks much better with the reflector removed. I tried pulling mine out yesterday and was not successful. I wasn't aware that it was held in place with tape. I will give it another try today. Thanks.
Old 07-27-2013, 10:36 AM
Killer Squirrel's Avatar
Killer Squirrel
Killer Squirrel is offline
I removed mine when I took off the stock side mount plate to put my own diy mount on. The rear fender is really easy to remove; remove the seat, unhook the quick connects along the back edge (there are 3 for the lights), take out the 4 bolts (2 on each side) of the fender braces below/behind the seat and then pull the whole fender assembly (with braces and all) up and forward. It then unlocks and you can remove the whole thing. Just make sure you have a towel or something to put it on so you don't jack up the paint. There is a plate/brace inside the fender that the reflector is held in with, you can see the brace removed in one of the pics, it is right next to the rear exhaust. You probably don't have to completely remove it to get the reflector out if you are careful. I don't know if any of these pics might help anyone visualize some of it but perhaps they will:
JustmeAP (04-27-2016)
Old 07-27-2013, 11:21 AM
P_RsBO's Avatar
P_RsBO
P_RsBO is offline
Second try was a success. I did not need to remove the fender either. I used a flat head screwdriver and rocked the bracket loose then pulled it off. Thanks again!
Old 07-27-2013, 02:44 PM
Pa-Rider's Avatar
Pa-Rider
Pa-Rider is offline
Well this makes me feel better.. I was thinking I was going to have to bust out the grinding wheel to get rid of that bracket under the fender!
Old 01-31-2014, 10:21 AM
Amber2014's Avatar
Amber2014
Amber2014 is offline
Default Its not coming!!
I used the techniques suggested on here to remove the back reflector (slot tabs, rocking back/forth, LIGHT Screwdriver pry) and it just won't come out. While I greatly appreciate this thread and the info provided by the members.....WTF?!! Going back tonight and trying again.
BTW, how do you guys like the new LED taillight strip available on ebay:
http://www.ebay.com/itm/281240443754...84.m1423.l2649
Ride on....
Old 01-31-2014, 03:10 PM
Stone Cliff's Avatar
Stone Cliff
Stone Cliff is offline
Ride on....
Mine would not come out with just prying up with a screwdriver either and I was afraid to go to far as I might crack the paint. One of the raised "****" came out of the slot but the other one I cut off with a dremmel tool, came out no problem. Believe it or not though - because of the huge gap between the fender and the tire, I put it back on - I think it looks better on.
Quick Reply: Breakout reflectors
