Softail vs. Dyna 96" bikes w/ SE-255 cam
Old 07-09-2013, 11:35 PM
tully_mars's Avatar
tully_mars
tully_mars is offline
Default Softail vs. Dyna 96" bikes w/ SE-255 cam
Ok, here I am a few months of riding now with all the cam changes in my bikes, and my Fat Bob w Stage 1 and SE-255 really woke up with new cam. However, the Fatboy Lo w Stage 1 and SE-255 really didn't seem to improve that much. You can feel it around 3000 rpm start to kick in, but below that it feels pretty much stock. It definitely doesn't pull like the Dyna does.
Does the counter balance on the softail just really hold those bikes back for low end torque? Is it the extra weight of the bike too?
Old 07-10-2013, 05:40 AM
rdc401's Avatar
rdc401
rdc401 is offline
check your tune,should be about the same.
Old 07-10-2013, 08:21 AM
rdc401's Avatar
rdc401
rdc401 is offline
Could also have the cam teeth off one notch,would be worth checking
Old 07-10-2013, 09:04 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
There's only about 15lbs difference in weight, and I can't believe the counterbalancer makes enough difference that you can feel it.
Old 07-10-2013, 09:43 AM
magnum629c's Avatar
magnum629c
magnum629c is offline
Yea I been on both there simlar.. Maybe a bad tune
Old 07-10-2013, 10:28 AM
Tailsfrommycrib's Avatar
Tailsfrommycrib
Tailsfrommycrib is offline
You don't see much concerning performance on the softail forum. The softails are not designed for performance but are made for relax easy riding.
Old 08-04-2013, 05:12 PM
tully_mars's Avatar
tully_mars
Checked compression and both cylinders came out at 190lbs spot on. Thus, timing is ok. I will play with the tune.
Old 08-04-2013, 08:33 PM
chillymac's Avatar
chillymac
chillymac is offline
B motors do not make as much HP as the other motors because of the balancer.
Old 08-04-2013, 08:40 PM
soft 02's Avatar
soft 02
soft 02 is offline
Fatboys are supposed to be slow cause they look so good. Who wants to be seen on a Dyna anyways.
Old 08-05-2013, 05:12 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
Well said. It's always great to see how good they look when I blow pat them on the old FXDL.
jhunter
General Topics/Tech Tips
08-11-2014 09:55 PM
pehenley
04-10-2013 09:46 AM
dew925
EVO
09-29-2011 04:15 AM
captain m
Exhaust System Topics
07-31-2007 01:57 PM
Quick Reply: Softail vs. Dyna 96" bikes w/ SE-255 cam
