Luggage Rack Platform/Plate Extension?
Old 07-06-2013, 12:58 PM
Biggerfoot's Avatar
Biggerfoot
Biggerfoot is offline
Default Luggage Rack Platform/Plate Extension?
I have a standard chrome luggage rack on my Heritage. On normal days, it is fine.
However, when loaded up with luggage for long trips, the weight of the luggage will cause the sides to sag as well as the outer edge. Over a period of time, it just keeps sagging more, losing space inside the bag.
Is there an extension platform out there that will not harm the chrome on the luggage rack? I figure I need up to about 18"w by 10" deep to keep my Ultra Tour bag from sagging. I was going to make one but figured I would see some ideas first.
Here is a photo I took on a roadside lunch break...the bottom bag is sagging over the luggage rack:
Old 07-06-2013, 05:00 PM
BARACU's Avatar
BARACU
BARACU is offline
Big Kahuna HDF Member
Received 3,567 Likes on 2,621 Posts
I have the same problem with a bag on my Heritage. I haven't gotten around to fixing it yet, since I only use the rack, backrest and passenger seat for extended trips when I need a large bag. I planned on securing a 1/4" or 3/8" piece of plexiglass to the inside bottom of the bag to stffen the bag. No harm done to the rack this way.
Old 07-06-2013, 05:18 PM
Biggerfoot's Avatar
Biggerfoot
That sounds like a good idea too. Plus you would not need to worry about the external rear straps. I am wondering if it would cause the entire bag just to tilt down at an angle though? I strap mine on the front side but still get the tilt down due to weight.
Do your side pouches sag too? I carry a couple of water bottles so they sag some.
My problem is only with extended trips too.
Old 07-07-2013, 09:36 AM
Biggerfoot's Avatar
Biggerfoot
I guess I was using the wrong search terms. I did find that Kuryakyn has a support to deal with the issue. It is pretty much what I was picturing.
The various reviews are fairly positive in that it works. eBay has it for $40.
http://www.kuryakyn.com/products/162...ng-bag-support
abadley
03-10-2017 03:29 PM
bob2002
Touring Parts
03-04-2012 02:46 PM
KevenW
01-30-2012 04:42 PM
Whiteduramax
10-01-2009 12:30 AM
streeter
04-23-2008 07:17 AM
Quick Reply: Luggage Rack Platform/Plate Extension?
