Compensator spring pack questions
Old 07-05-2013, 04:48 PM
remmag's Avatar
remmag
remmag is offline
Default Compensator spring pack questions
Hey guys
Need your input
I have a 03 road king with a hillside 98" build,bike tuned by Stroker Jlk
I have been getting a noise from a dead take off in first gear,kind of a clanky rattle
It only happens when taking off from a dead stop and if I work the clutch and gas just right it won't do it
Also if the bike is cold it don't do it
I put a new clutch in hoping to take. Care of it but it did not
Could the spring Pak on the comp be doing this,was there problems with the springs on these
I don't want to give mother harley $160.00 on a guess
Thanks guys
Old 07-05-2013, 07:38 PM
maddghost's Avatar
maddghost
maddghost is offline
If your handy I would suggest open up your primary and take the comp sprocket apart, clean it and check the compensator cam for drag marks. They have been known to come loose now and then. then torque it down put it all back and it may just be solved.
PS the book says over and over to change your 30$ steel primary gasket, I've had mine off and back on three times without a drip.
Skullking101
05-31-2019 09:50 PM
BCass53
09-25-2016 08:08 AM
jurgie
Exhaust System Topics
07-31-2012 01:39 AM
JosephGarcia
03-20-2009 02:35 AM
mplecha
09-26-2008 03:49 AM
Quick Reply: Compensator spring pack questions
