2007 Ultra Classic Stalls When Clutch Pulled
Old 06-24-2013, 11:46 PM
General Lee01's Avatar
General Lee01
General Lee01 is offline
Stage I
Default 2007 Ultra Classic Stalls When Clutch Pulled
I have a 2007 Ultra Classic that is having a problem stalling when the clutch is pulled. I have taken the bike to 2 different shops and the bike shows no codes. The bike also doesn't do it frequently enough for it to luckily happen when they ride it.
I will be riding along and come up to a stop signal or sign and pull the clutch to downshift and the bike will start to stall out. The bike generally holds at 1k rpm, but when this problem happens I have to keep the throttle engaged to keep it running. I have been told the bike spits out smoke when this happens also.
Other than this the bike runs like a dream. This probably happens 1 in 5 rides. The only way I can stop it from happening is to turn off the ignition and turn it back on or it will continue to do it. Once I restart it, it completely stops doing it and runs normal again.
Anyone ever have this issue?
Old 06-26-2013, 02:08 PM
rjammo's Avatar
rjammo
rjammo is offline
yep, I have a 07 Road King Custom with the same symptoms. Low idle and dies when I pull in the clutch. Very erratic...hasn't happened in the last 4 or 5 rides. Once it starts acting up I'll turn it off, restart, and all is good. I've cleaned the ECM with carb cleaner, cleaned the air filter, and remapped with my power vision with little success. It's irritating yet not to the point of taking additional action. There are additional posts on the forum that discuss the issue (search "low idle").
Old 06-26-2013, 03:47 PM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
I have an 07 as well and it would high idle at times.The name escapes me at the moment but it is a little plunger in the intake manifold that I cleaned a couple of times..Don't know if this may be related.
__________________
www.Captain-Itch.com
Old 07-29-2013, 07:47 AM
kdarsey's Avatar
kdarsey
kdarsey is offline
Stage I
OK... My 07 Ultra Classic did this 3-4 times yesterday at the end of about a 250 mile ride. It has never done it before. Of course I have only had it for about 3K miles.
Still no answer??
Old 07-31-2013, 11:51 AM
tuna1's Avatar
tuna1
tuna1 is offline
I had it happen to mine and replaced the sensor for the speedometer. Watch when it does it and see if your speedometer goes to zero while your still slowing down.
Old 07-31-2013, 02:18 PM
Kenney's Avatar
Kenney
Kenney is offline
You didn’t say if you were totally off the throttle (closed) when this happens or still had the throttle slightly open.
Warm the bike up, open the throttle, (22K – 25K should do it) and let the throttle “Snap” closed and see if it wants to stall.
leachman
12-19-2015 04:03 PM
rwt
05-19-2015 09:20 AM
dkc061
12-04-2014 08:16 PM
epd612
08-14-2012 07:50 AM
roadmaster56
01-21-2011 05:30 PM
Quick Reply: 2007 Ultra Classic Stalls When Clutch Pulled
