Pant Leg Ride Up
Old 06-19-2013, 01:16 PM
sambo42xa's Avatar
sambo42xa
sambo42xa is offline
Default Pant Leg Ride Up
Here's a goof question........WHY is it only the left pant leg rides up over my (work)boot when I ride and not the right pant leg? I thought maybe it's because of using the shifter, but you use the foot brake too and it just does not seem to do it on the right side. Come on, anyone else run into this or am I now starting to believe I have one leg longer than the other (did I just say that?!)? This is of course when using the floor boards.
Told ya it was a goof question.
Old 06-19-2013, 01:18 PM
sambo42xa's Avatar
sambo42xa
.......and as you're riding you reach down and pull the cuff back over your boot. Then you look down and it's back over again!! WTF?!
I think I need velcro................
Old 06-19-2013, 01:19 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
Buy longer jeans and taller boots!
Old 06-19-2013, 01:21 PM
Car Doc's Avatar
Car Doc
Car Doc is offline
I think I look pretty cool when I get off and my pant cuffs are rolled up it like I did it on purpose go with it I say.
Old 06-19-2013, 01:28 PM
FNGonaRK's Avatar
FNGonaRK
FNGonaRK is offline
Received 7,666 Likes on 2,676 Posts
I don't fight it. I kick my feet up on the highway pegs and enjoy the breeze. I do occasionally hop off the bike at the destination and forget to roll them back down too. Oh well. I gave up on being cool a long time ago.
Old 06-19-2013, 01:31 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,646 Likes on 4,633 Posts
the rotational vortex of the rotor turning at half the speed of the rear tire creates a turbulence that reverberates off the down force from the ft fender causing a severe uplift off the front of the primary, seeking the low pressure area within the draft of the left pantleg.
I got nothing!!
vizcarmb's Avatar
vizcarmb
vizcarmb is offline
Im not going to comment on this comment. That is some straight left field **** right there
Old 06-19-2013, 02:01 PM
Coastal CVO's Avatar
Coastal CVO
Coastal CVO is offline
It's always my right leg. That is where I keep my gun so it bothers me...
I always check when I see a cop just so I don't have to explain.
Old 06-19-2013, 02:03 PM
DNC's Avatar
DNC
DNC is offline
Had a similar issue a while back, but got longer pants and the problem went away. You could always get some of these if it's really bothering you.
http://www.ebikerleather.com/_e/dept...ts_Keepers.htm
Old 06-19-2013, 02:08 PM
magna's Avatar
magna
magna is offline
Can't say I've had the problem but there again my riding jeans are 2" longer than my other jeans, in your case it's probably because your right leg is pressing against the AC so stoping it riding up.
Quick Reply: Pant Leg Ride Up
