lowered front fender
Old 05-24-2013, 01:19 PM
scottsflstf's Avatar
scottsflstf
scottsflstf is offline
Default lowered front fender
In anticipation of recieving the rear lowering bolts for my fatboy, I decided to lower the front fender while waiting for the mail man. I removed the fender, put a piece of a rubber hose on top of the tire then placed the fender on top of that. I spent alot of time making sure that there was going to be enough clearance before marking where my new holes were going to be. Then I started drilling.
I used a uni-bit to get the size of hole I needed to just get the bolts through.
I raised the bike then mounted the fender and double checked the clearances making sure nothing was rubbing.
I took it around the neighborhood and everything seems just fine. I just need to cut the excess off and touch up the edges, but I'm going to ride it some more before doing that, in case I find that I have to go back to the stock position, in which case I'll just fill the new holes in and touch it up with black paint. But, so far it looks like it is going to work. Here is a before and after shot...
And a full view...
I'll post pics after I lower the rear and after I cut the excess off the front fender and touch it up. Now, come on postman!
Old 05-24-2013, 02:11 PM
Jake911's Avatar
Jake911
Jake911 is offline
Looks nice. I almost did the same thing a coupe days ago when I replaced the front rotor and had the wheel off. Looks like about 1/2" or 5/8" difference? I was thinking the plastic hole plugs would work to hide the old mounting holes.
Old 05-24-2013, 05:06 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
The rule of thumb for clearance is usually 5/16 or so. Tape a 5/16" nut to the middle of teh tire and spin it around and see if it scrapes. If not you should be good.
Old 05-24-2013, 08:09 PM
scottsflstf
i got the rear lowered...
Old 05-24-2013, 08:14 PM
elizer's Avatar
elizer
elizer is offline
a definite noticiable difference.
Old 05-24-2013, 09:48 PM
ghoticov's Avatar
ghoticov
ghoticov is offline
Very nice! Looks great.
Old 05-24-2013, 09:50 PM
Shortmag's Avatar
Shortmag
Shortmag is offline
Lookin good
Old 05-25-2013, 12:49 AM
Lightafatty's Avatar
Lightafatty
Lightafatty is offline
I lowered and chopped mine also. Looks much better sitting closer to the tire.
Slamed Slim
05-04-2015 09:06 AM
megathumpzilla
12-22-2013 03:57 PM
Bobber Jake
03-12-2011 07:18 AM
timberland
06-13-2010 09:43 AM
mojojones
07-09-2009 02:13 PM
Quick Reply: lowered front fender
