2013 Street Glide with 120R
Old 05-21-2013, 07:15 PM
abidzip's Avatar
abidzip
abidzip is offline
Question 2013 Street Glide with 120R
Decided to pull the trigger and trade my Road King for 2013 Street Glide and purchasing the 120R motor. Going with the Rivera pro clutch, D&D Boarzilla and the SE heavy breather and the SE Pro tuner. Now the question is I am thinking about installing the Hurricane heads with SE rolling rockers and the 64MM throttle body. Has anyone done this combo with 10.5:1 pistons? If so what were the pros and cons? Some suggest the 58MM with the MVA provided heads, others say keep the MVA heads and get the 64MM. I do plan on a dyno after all is said and done. I have heard the pros about a different cam and the 12:1 pistons and maybe a new transmission but I am not $$$ ready at this time although I may explore that option down the road in a few years.
Old 05-21-2013, 07:22 PM
vickers1's Avatar
vickers1
vickers1 is offline
Wow! Doing that to a 2013??
Old 05-21-2013, 08:54 PM
POP TOP's Avatar
POP TOP
POP TOP is offline
Was riding with a guy here last week that has the 120R in his street glide, all I can say is wow!!
Old 05-22-2013, 04:40 AM
abidzip's Avatar
abidzip
abidzip is offline
Yes absolutely, so when it come time to sell this bike I can put the 103 engine on with little or next to no miles on it or if I blow up the 120R I have backup! Now if some people can assist me with my questions it would be greatly appreciated!
Old 05-22-2013, 05:53 AM
grbrown's Avatar
grbrown
grbrown is offline
There are not many threads on the 120R, so use Search to read through them. Hurricane heads have been mentioned, but not often. Sounds like an interesting project!
Old 05-22-2013, 05:57 AM
MikeTD3's Avatar
MikeTD3
MikeTD3 is offline
Not much for chit chat? Funny stuff.
Old 05-22-2013, 06:01 AM
scj's Avatar
scj
scj is offline
If you're leaving the stock cam in it, the best mod you can make is more compression. Bigger heads will kill any bottom end, same as a bigger intake if you do not have the compression to compliment it..
Most use thinner head and base gaskets to bump the compression.
I actually took the 266 cams out and went with smaller 260 cams since I plan to put a lot of miles on it and just do not want that much lift.
I am going to install the thinner Cometic head gaskets since I am all about low end torque.
Old 05-22-2013, 06:08 AM
Pete6114's Avatar
Pete6114
Pete6114 is offline
Mind sharing who done the work and what was the price-tag? Any dyno-numers?
RK Joy's Avatar
RK Joy
RK Joy is offline
Your SG sounds like a beast. Good luck with the mods!
Old 05-22-2013, 06:10 AM
sporacer's Avatar
sporacer
sporacer is offline
the hurricane heads need compression and a bigger cam. I have seen some people get great results with more compression and a cam change to get more torque down low. What kind of power are you looking for and what type of riding do you do? I have about 20000 miles on mine and just did a compression test. It was still perfect.
Quick Reply: 2013 Street Glide with 120R
