DIY Air Cleaner (Heavy PIC Content)
The inspiration of this AC came from Streetfighter06. He had a similar setup on his ride and I think it looks as good as any big name ACs out there but for a fraction of the cost.
It took me a couple years to get around to actually work on this. Ironically, the weekend after I bought my filter and end cap, I saw another member here had gotten the same idea. For that, I need to thank groverhd for putting his thread up here and letting me see the final appearance. See, I was trying to determine if I wanted to vent through breather bolts, an independent filter or directly into the intake like the stock set-up. I decided to go the breather bolt direction.
Time beginning to end, a little less than an hour. Cost, roughly $65.
Following is a complete step-by-step photo process: (apparently, I am limited to 20 pictures, so I had to cut a few out)
Remove two allen-head screws holding the AC cover.
Remove 3 torque screws holding the filter
Carefully remove filter gasket (will be reused)
Remove two breather bolts
Back plate slides straight off
New Filter (Pep Boys/$19) and drain cap (Home Depot/$1.50)
Use gasket as a template for drilling holes in the drain cap. Make sure gasket is facing correctly. The extra hole should be positioned in the upper-right.
The filter can accommodate multiple size mounts: 3”, 3.5” & 4”. There are removable rings on the backside to allow the opening changes. Since the end-cap I used has a 3.5” outside diameter, I needed to remove the center ring from the filter.
Place the end-cap into the filter and trace the edge to get a cut line
End-cap marked and ready to go
Use a 2” hole saw for the center cut-out then drill the mounting holes
After removing all stray pvc splinters, test fit the holes
Small hand saw to cut the cap down to size
Roughed out custom mounting plate
All edges and mounting surface sanded smooth (started with 220 grit, finished with 600)
The original screws are too long for this set-up, so you need three ¼” X ½” long, course thread screws (Home Depot/$2)
Breather Bolts from DK Custom ($38) BTW, ordered LATE Tuesday night … arrived Friday morning. Amazing shipping time. You guys rock! Thanks Kevin!!
Mounting plate and Breather bolts installed
Air filter slips on and is held on by a stainless steel clamp. It extends out the same as the stock ham can but has a smaller overall footprint.
Well, already had the 2:1 exhaust and a fuel pak to eliminate decel pop. The bike had been running a bit rich w the stock ac. Since there is no true setting on the fuel pak for pipes and stock ac, the fuel ratio should be better now.
The bike feels good, soubds good and no hesitation or popping after the change...so I think this will be ok.
Forgot to mention in the original write up. Use a drop of blue lock tite on the bolts to keep everything in place with the engine vibrations. Also, I am not a chrome fan....I see some sanding and flat black in my near future.
