carb leaking
carb leaking
I reset the float level on the stock carb (non CV ) on the 89 Heritage as it was leaking out the overflow every once in a while last year. It was set to about .74 inch and I set it down to about .66inch and it seems to be worse now then last year. I figured I'd try the float setting rather than change the needle as thats just me and my troubleshooting.
So is .66inch on the high side compared to .63inch? Manual says set between .63-.67inch. Seems I made it worse going lower in the number.
Also book shows the carb held on a slight angle and measure from bottom of float( if the carb is held upright it would be the bottom) to the base and is the float suppose to just lightly rest with needle closing off flow ? So slant the carb just enough so float needle closes softly? Perhaps I should just change the needle?
Hope this makes sence.
Also noted there was a crack on the plastic fuel inlet, I understand this is a known issue, but what is the fix?
You hold the carby on the slant, lower the number the higher the fuel level in the bowl.
I am not sure but maybe the brass CV fuel fitting conversion works with the butterfly?
Why not just biff the butterfly and stuff a CV on there, hell, I'll even send you a free manifold and gasket if you get the carby :-)
This carb just seems to operate so well other than the cracked inlet which isn't leaking yet, and the overflow problem. I guess I just enjoy fiddling.
Do the plastic inlets tend to break internally or are the cracks on top just external to these carbs? I'm concerned that we can be out on the road and it all of a sudden snaps, then she would be freaking out.I may have to duck into the Softtail forum and see if I can dig up some info on what there using for enrichener cables. Wish me Luck.
Received 4,317 Likes
Hope this helps.
Thanks Spanners, funney you say that about the cv, I just ordered a cv manifold off ebay. I do have a cv carb from my bike sitting on the shelf and I think if I remember correctly it just needs the enrichener piece that goes in the side of the carb, I had replaced it with a Dales Killer Carb. Would the enricher cable just go through the dash on her Heritage but possible longer one needed than the one I use which goes right out the side below the petcock?
