Need Input-Radials on spoked wheels
Old 05-02-2013, 10:46 PM
U.P. Lou's Avatar
U.P. Lou
U.P. Lou is offline
Default Need Input-Radials on spoked wheels
I know I'm getting older and the mind is not what it once was, But, I need input on installing radial tires and tubes on my 2001 Heritage Softail Classic with spoked wheels.
Do I remember that this should not be done or am I just losing it. I want to install Metzeler 888's radial, versus 880's which are bias. Heard a couple of bad things about the new 880's after some manufacturing changes at Metzeler, which very well could not be true. (Who would think that a salesperson would bad mouth a product because he wanted to sell you what he had on hand ?) I sure liked the 880's I bought 3 years ago on another bike, but am set on the new 888's if they will work. Any input will be greatly appreciated. Thanks-Lou
Just got off the phone with Metzeler. The 888's that are presently available are BIAS Ply tires, not radials. Their website is confusing at least to me in that it does not specify this however, it does go on to talk about radials, so anyway, this post is wacko---Thanks for looking at it---Lou
Old 05-05-2013, 01:50 PM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Lou, I can't see any problems of using radial tyres on spoked wheels. The thing to be wary of is using a radial front and bias rear, although I have never understood why that should be! A bias front with radial is OK and what I currently run.
Wacko post or not, I'm sure you'll be fine!
Old 05-05-2013, 01:56 PM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,553 Likes on 3,058 Posts
The radial's wall tends to allow slightly more roll, and installed on the front with a bias in the rear would increase the chance of a front end washout, ( from understeer.)
The radial in the back with the bias in the front (as you have,) causes a slight slight oversteer, but that's not a problem riding that way.
Old 05-05-2013, 02:47 PM
checkers's Avatar
checkers
checkers is offline
The 888's are bias tubeless tires, not radial's. They do have a reference on their web site of them having a radial belt, but they are not radial ply tires. I have a set of the 888's ready for my Heritage when the Dunny's are gone. Dennis Kirk had the best price on them last week. The 888's will be replacing the 880's across the board when Metzeler has the sizes avail.
Old 06-09-2013, 08:35 PM
rodhotter's Avatar
rodhotter
rodhotter is offline
bias tires + damper rod forks are long outdated poor performing stuff but cheap which is why harley + others still use them, suspension is hard to tune due to different riders, tire use also varies, you get wear or traction or some compromise of
Old 06-10-2013, 10:32 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
There's nothing wrong with bias tyres! However damper rod forks are indeed long overdue their pension. I suspect when the MoCo finally grab the nettle and update the suspension they use across the model range, it will come as a shock to many long-standing owners!
Old 06-12-2013, 01:48 PM
onespeed's Avatar
onespeed
onespeed is offline
Good Thread.............I am at this time trying to make the exact same decision.
It would be nice to hear from someone who actually did put radial tires on a softail bike and how it does ride and handle.
I called MOCO and asked about this and there response was " they cannot recommend anything other than what is in print (the owners manual) D402 bias-ply.
I seriousley want to switch to radials.
billbrummett
06-01-2020 04:19 PM
Kyle Moore
06-16-2019 06:28 PM
Sorg67
EVO
04-26-2017 05:36 PM
mike1158
06-02-2013 11:58 PM
Late Bloomer
11-01-2009 11:08 AM
Quick Reply: Need Input-Radials on spoked wheels
