Headlight problem, no low beam, only high
Old 04-22-2013, 09:42 AM
milesvdustin's Avatar
milesvdustin
milesvdustin is offline
Default Headlight problem, no low beam, only high
My headlight does not work on low beam, only high. I have tried three different bulbs, same issue with all of them. Is there a relay or something that controls this? I removed the wires from the stock headlight and installed them in a new bucket, and the wires are going to the same holes in the connector that they came out of. There is yellow, white, and black wires. The plug on the wiring harness side has an extra orange wire, not sure what it does. All I did was change the wires, nothing else. I am going to attack it with a meter later. Any common things that would cause this?
Old 04-22-2013, 12:24 PM
nevil's Avatar
nevil
nevil is offline
Problem with the headlight switch?
Old 04-22-2013, 12:38 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Connector not plugged properly or corroded pins?
Old 04-22-2013, 01:03 PM
milesvdustin
I checked the connector, it is solidly connected, and the pins are clean and free of any corrosion. It just stopped working....
Old 04-22-2013, 01:28 PM
FXD2003Rider
Now try to find out if there is 12 v to the white (high beam) and yellow (low beam) wire inside the headlight bucket.
If there is, check if the bulb studs touch the tabs inside the fitting.
If there isn't, check for 12 v at the connectors.
Old 04-22-2013, 01:38 PM
milesvdustin
I think my plan is to check for the voltage at the pins in the headlight. If I dont have low there, which I am positive I dont, then I will go to the left handlebar switch plug and check for continuity through the switch. If thats good, then I am not sure where to go from there. Is there a relay that switches the headlight between high and low? Im at work and dont have my manual with me at the moment.
Old 04-22-2013, 01:53 PM
FXD2003Rider
No relay for the high/low beam.
The handlebar switch is 1 in, 2 out.
Since you have 12v at high beam, the issue is in between the switch and the lamp fitting or the bulb itself. Another option: a torn/pinched yellow wire might be the issue?
Old 04-22-2013, 03:48 PM
milesvdustin
I see what you are saying. It is either the low side of my switch or the wiring from the switch to the light. Should be easy to track down once I have my meter.
Old 04-22-2013, 06:41 PM
milesvdustin
Broken wire on the headlight pigtail! It was broken right inside the grommet for the headlight. I guess I screwed that up when I swapped it over. Time to install the HID kit!
AtticusFinch
09-11-2013 07:15 PM
Stick_Drifter
EVO
07-18-2013 06:17 AM
oldguyalso
01-31-2010 10:18 AM
klf33
05-30-2008 10:46 AM
2007fxdc
12-27-2007 03:23 PM
Quick Reply: Headlight problem, no low beam, only high
