Transmission (Gear) Oil
Old 04-21-2013, 08:50 AM
SanJuanRon's Avatar
SanJuanRon
SanJuanRon is offline
I have used Redline Shockproof Heavy for many years with good luck; except for the awful smell when the bike gets warmed up and your sitting at a stop light. SJ Ron
Old 04-21-2013, 08:58 AM
Loc_Tite's Avatar
Loc_Tite
Loc_Tite is offline
I'm glad I'm not the only one who's noticed that smell. I was looking for leaks at my seals when I started using it
Old 04-21-2013, 09:01 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,324 Likes on 3,269 Posts
I tried different ones but went back to Formula plus...shifts fine...Just remember to actually change it.
Old 04-21-2013, 10:22 AM
stro1965's Avatar
stro1965
stro1965 is offline
I love Shockproof! But I've noticed the smell occasionally too. All I know is my bike shifts like butter and finding neutral is easy peasy.
Old 04-21-2013, 12:05 PM
beakerztoyz's Avatar
beakerztoyz
beakerztoyz is offline
Originally Posted by RK4ME
In all my years of riding, I've never had to "research" anything other than the owner's manual for the recommended lubricants. Any good quality 4- stroke motorcycle oil will give a Harley transmission all the lubication it needs, and a Harley transmission doesn't even have to share its oil with the engine. I run Mobi1 V-Twin 20w50 in mine.
Well you must know more than some of us, the factory manual for my 95 softail doesn't list any specs on what goes in the transmission or primary other than HD part numbers and being new to harley's I really have no clue either what goes in them.
would the 75/90 or 75/140 gear oils be the stuff to use in the 5 speed in my evo as well?
Old 04-21-2013, 12:54 PM
oldairboater's Avatar
oldairboater
oldairboater is offline
I use 75/140 in my Evo and Twin cam transmissions. Like stated above it quiets done the clunk, neutral is easier to find. Harley's ran a heavier gear lube in the past and these transmissions haven't changed much---just go more crowded. I didn't like the lighter oils in my transmission.
Old 04-21-2013, 05:18 PM
IMG2's Avatar
IMG2 is offline
While the used bike I bought came with a lot of neat goodies, it didn't come with an owner's manual.
Old 04-21-2013, 05:41 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
75/90 wt gear oil is about the wt of 50 wt oil. the 75/140 is about is about 60 wt. Your really not putting some super heavy, thick oil in the trans. Unless you have bent shift forks ,they all shift about the same. What will make the biggest difference in shift quality, is what you use in the primary. I've found that 20/50 wt oil seems to cause drag on the clutch plates. Which is why most bikes have that loud bang when putting the bike in first gear. Kinda like your shifting without using the clutch. I've found that 10/40 or 15/40 wt oil works the best for me in the primary, but some guys use atf., but say the shift quality gets notchy after a while.,,
Old 04-21-2013, 11:35 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,210 Likes on 1,380 Posts
I ran Syn3 in all 3 for my RK's first 50k miles and I've used HD's Formula+ with no problems but I think it's a bit sticky for the clutch so I Valvoline 10w40 non-syn motorcycle oil in the primary. AutoZone is about 25 miles closer to home than my HD dealer. I've got to believe that HD Formula+ is lighter than the Hypoid gear oils that so many people put in their Harleys' transmissions.
liv2hunt
42
01-17-2012 03:22 PM
Woodchuck
06-18-2011 12:37 AM
jp13
Oil Archive (no new posts)
04-06-2010 09:09 PM
J-Train
10-02-2009 10:20 PM
HDV-GLIDE
08-21-2008 08:23 PM
Quick Reply: Transmission (Gear) Oil
