Later Evo compression problem
Old 04-20-2013, 12:15 AM
Fear2722's Avatar
Fear2722
Fear2722 is offline
2nd Gear
Default Later Evo compression problem
Hey All -
I have a later style Evo motor, rear cylinder has ZERO compression. Front has 100+ PSI. The cylinders were bored/honed and matched to new pistons before I bought it.
Anyway, upon my investigation, the rear cylinder has a GREEN pushrod for the exhaust, and a YELLOW one for intake. The book says it is supposed to be PURPLE for rear, and BLUE for intake, and the Green/yellow should be up front.
Not to get the cart too far ahead of the horse, because I haven't popped open the front cover yet... But if these pushrods are installed ***-backwards like I believe, would this give me the zero compression reading?
I'm guessing the guy I bought this from, who built it for me, just had parts laying around enough to call it an engine.
Thanks.
Old 04-20-2013, 08:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
If the pushrod is longer than it should be it could prevent the valve from closing fully, you must get them installed in the proper positions.
There is nothing wrong with one piece pushrods, as long as they are used with a compatible cam and are installed in the proper position.
HintonTM
Engine Mechanical Topics
03-27-2019 08:20 PM
Rodewarrior1981
Shovelhead
16
09-08-2018 10:37 PM
harley7316
EVO
07-06-2011 04:13 PM
jhnmflr
Exhaust System Topics
18
10-16-2009 07:23 PM
bma1977
03-29-2009 08:58 PM
Quick Reply: Later Evo compression problem
