Led passing lamps.
I ended up going with the Truck Lite P7 headlight & passing lamps- just manually tweaked them till I was satisfied with their aim?
I did use the HD independent harness (part # 69200441) though.
I like the option to be able to run my passing lamps with the high beam on.
Speaking for myself- I can never seem to have enough light pointing down those dark, desolate roads, the more light the better!
I don't have a wall wide enough to see the whole light pattern and have a hard time lining up the center of it with the mark on the wall.
Also a **** poor setup to adjust them. Removing the signals then the nut, aiming the light and tightening it without loosing the setting and keeping the signal light base in line. I think they tighten it and use force to move the passing lamps....Sucks....
The order the harness is supposed to run is:
power from fender clip light plug
through the new harness
connects to the grey/black wire supplying the aux lights
Following the directions caused mine to be:
connects to the yellow wire coming from the high beam relay
This caused my aux lights to not work ever, no matter what position the switch was in or whether the high beams or low beams were on. There just wasn't power going to the aux lights at all.
Once I discovered the issue, I trimmed dog ears on the aux light connector so I could install it upside-down and the aux lights work perfectly now.
The moral of the story is this: do not determine which wire to depin and cut based on where it attaches to the aux light switch. Depin and cut the wire that connects to the yellow relay lead at the white connector.
Instrction sheet- passing light aiming
I don't know how to download from the hd site,but you want -J50236pdf
http://www.kuryakyn.com/Product-Gall...ame=5496-1.jpg
For what it is worth when I did the change to LED lights last fall after a rough adjustment I took them out on the road for a final adjustment. Got them just the way I wanted them in actual use.
Of course we live on road that doesn't have much traffic which helps do the adjustments on the road.
