Loose Compensator Nut
Old 03-25-2013, 12:02 AM
robvg's Avatar
robvg
robvg is offline
Default Loose Compensator Nut
Installed new Hayden primary chain tensioner & checked torque on compensator nut while primary cover was off. Got about 1/4 turn on it before the torque wrench clicked. Should I loosen it, re-loctite and retorque or will the snug-up be OK?
Old 03-25-2013, 12:14 AM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
I would... remove, clean all threads (internal & external) & reapply loctite & torque to specs.
Old 03-25-2013, 12:16 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
Old 03-25-2013, 02:21 AM
Watch Guy's Avatar
Watch Guy
Watch Guy is offline
Default I've always been lead to believe that
you should never try and re torque a bolt. Remove and re torque.
Old 03-25-2013, 04:20 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
For high frictional conditions the magnitude of the torsional stress can be such that when combined with the direct stress, an equivalent stress over yield can result, leading to failure. A more consistent approach is to determine the magnitude of the direct stress which, when combined with the torsional, will give an equivalent stress of some proportion of yield......
Yeah, try that.
Actually I would leave good enough alone, not that big a deal, the loc-tite will reseal.
Old 03-25-2013, 04:39 AM
brownfoxx1's Avatar
brownfoxx1
brownfoxx1 is offline
the manual for my '09 t/g says you check the first time at 20k miles but not at 25k. mech. found mine worn but serviceable.(took nut off & re-applied blur locktite & torque to specs.and guys usually upgrade to the S&S one which i hear has slightly better libricarion
than the OEM version.
looks like you found it just in time; when it starts banging (the first time you hear it) i,m told shut bike off, or get it home & ck it immediately.
if you let it bang then you will have to replace it.
the reason i'd like to know your miles is the mech should have ck'd it at 25k & re-locktited the nut. if its loosening up againg lets say at 32k.
then you have a problem in the near future, because it seems the nut will loosen-up in a few k miles.
Old 03-25-2013, 07:59 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
If I am not mistaken, the compensator nut has the highest torque value of any fastener on the motorcycle. At 140 lbs, there is a lot of nesting stress applied to the threads. If you remove that bolt, I would never re-use it. These bolts are not expensive. Got to the HD shop and get a new one and install it per the manual....First to 100 ft lbs, back off one full turn, then all the way to 140 ft lbs. I always add a little red locktite regardless of that yellow **** they put on the factory bolts.
About your question of tightening it and moving on...well...you broke the locktite set so the loctite will never reattach as well as it does initially. If it was me, I would back out the old bolt, get the new one, get a damn good torque wrench...not some cheap piece of **** from China...and re-install it the correct way. And use the correct locking bar when locking down the sprockets....not some soft *** piece of wood that will slip.
Old 03-25-2013, 08:04 AM
alame's Avatar
alame
alame is offline
not quite true there....its done all the time when a retorque is required on the "jesus" nut that holds the head/blades on a helicopter but no Loctite is applied so its a bit different
Old 03-25-2013, 10:24 AM
bagman1's Avatar
bagman1
bagman1 is offline
You sure it says blue locktite? Every manual I have ever read says to use red!
Old 03-25-2013, 08:35 PM
customsoftail200's Avatar
customsoftail200
customsoftail200 is offline
RED loctite.. Make sure you clean the threads of all the old loctite and torque it down.. Sucks when they loosen up, mine did about a year ago, stator and rotor got banged up and damaged the threads on the crank. I sat there for about an hour with a thread file to straighten and then ran a thread chaser over it.. Long process but it worked...
Quick Reply: Loose Compensator Nut
