2003 883 not starting solenoid/relay ?
Old 03-18-2013, 11:47 AM
naturalhighvpc's Avatar
naturalhighvpc
naturalhighvpc is offline
Stage II
Default 2003 883 not starting solenoid/relay ?
I have a 2003 sportster 883 over the winter I did some work, side mount plate and tail light,coil & ignition relocation, new builtwell bars new paint. When I got it all back together all seemed good all the lights worked and systems came to life but when I hit the start button I got NOTHING. I checked the (4) 15amp fuses in the fuse box, all are good. although when I was hooking up the tail light on the side mount bracket I did blow some of those 15amp fuses I replaced them right away and moved on.
? could I have blown the starter relay located by those fuses at the same time I blew the 15 amp fuse?
? how do I know if the starter relay is blown ?
? could one of my problems be the starter solenoid?
any help in diagnosing this would help greatly Thanks VC
Old 03-18-2013, 08:15 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
ignition switch relocation? are you sure you go the wires back on correctly?
easy way to tell about the relay is listen for it to click when you hit the start button. if it's not clicking, then you're either not getting power to it or you're not getting the start button feed to it.
Rickk Lauderdale Smith
Engine Mechanical Topics
07-27-2020 03:52 PM
Dopey
07-01-2019 12:07 PM
trike1946
04-09-2019 06:05 PM
Mercdwarf
Shovelhead
09-18-2018 09:06 PM
ape.hanger883
08-21-2008 08:49 PM
Quick Reply: 2003 883 not starting solenoid/relay ?
