Best Oil Filter
Old 03-16-2013, 03:15 PM
hunter1jonathan's Avatar
hunter1jonathan
hunter1jonathan is offline
Default Best Oil Filter
I have a 2013 Ultra classic and was wanting to know which aftermarket oil filters are the best to use. I'm looking for an increase in MPG.
Old 03-16-2013, 03:34 PM
BeeRAD56's Avatar
BeeRAD56
BeeRAD56 is offline
Welcome to the forum. You can expect some interesting answers since oil filters and fuel mileage are not related.
Old 03-16-2013, 04:21 PM
WAYJO's Avatar
WAYJO
WAYJO is offline
You expect an oil filter to help in mpg? Lemme know how that works out for ya. If you want a good quality oil filter that is user friendly because of the nut welded on the end to make removal easier, then I suggest the K&N filter.
Old 03-16-2013, 04:23 PM
Zakk13's Avatar
Zakk13
Zakk13 is offline
I like the Harley filters...
Old 03-16-2013, 04:29 PM
backroads-2's Avatar
backroads-2
backroads-2 is offline
why would you do that? have you ever checked filter tests,being a lifetime wrench and seeing dammage done by aftermarket parts I would never run anything but oem,
Old 03-16-2013, 04:39 PM
Vettely's Avatar
Vettely
Vettely is offline
K&N oil filters!!
Old 03-16-2013, 04:50 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
I like the Amsoil filters,and i've tried every oil filter (except mesh/screen) including bosch and purolator. These give me less blowby and i'm pretty sure they're made in the USA.
Old 03-16-2013, 04:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,482 Likes on 4,605 Posts
Something smells fishy...
hunter1jonathan
I noticed that K&N's are recommended for increased performance. Saw a review that someone had an increase of 5-10mpg between fill ups from changing to a K&N using a 99' Road King . I read off AMS oil's website that better oil flow through a filter increases efficiency. Better efficiency often leads to less work meaning less fuel and or more power. Just wanted to see if anyone else noticed a difference if they had switched from stock filters.
Old 03-16-2013, 04:55 PM
12hdrk's Avatar
12hdrk
12hdrk is offline
Seriously? Where is the candid camera?
Quick Reply: Best Oil Filter
