Stripped screw hole on my fairing..any ideas?
Old 02-12-2007, 03:48 PM
ezglider's Avatar
ezglider
ezglider is offline
Default Stripped screw hole on my fairing..any ideas?
I noticed that one of the screw holes that connects my outer and inner fairing is stripped on my RG.It looks like the screw holes are plastic and I don't see any kind of bracket in there that can be replaced. Is there anyway to fix this without having to replace the whole outer fairing?
Old 02-12-2007, 03:56 PM
Phrogman's Avatar
Phrogman
Phrogman is offline
Default RE: Stripped screw hole on my fairing..any ideas?
Go see your dealer. I had one of my windshield captive nuts detach from the inner fairing due to overtightening by the mechanic there. They replaced it no problem. There should be a captive nut on your inner fairing as well, if not then maybe they can put one in.
Old 02-12-2007, 03:59 PM
ezglider's Avatar
ezglider
ezglider is offline
Thanks man I'll check it out.
Old 02-12-2007, 04:21 PM
geargrinder's Avatar
geargrinder
geargrinder is offline
I've pulled the captive nut out, mixed up some JB Weld, put some weld in the nut hole, coated the outer nut, reinstalled nut, let dry for 12hrs, installed screwand learned never to over tighten them.
bluesgub's Avatar
bluesgub
bluesgub is offline
You might be able to re-thread the fitting if you have a tap and die set.
Old 02-12-2007, 05:01 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is online now
Last time I had the fairing off it looks like the screws in the inner fairing are only threaded into plasticinto the outer.I saw no type of insert what so ever.Infact one of mine are stripped also.I know the dealer did this during warranty work but have never took it it back.
The next time the fairing is off,I'm going to install thread inserts in the outer fairing.
Helicoils,Timeserts,Spiralocs would be better than the factory setup.
Old 02-12-2007, 05:03 PM
SubZer0's Avatar
SubZer0
SubZer0 is offline
There are no captive nuts on the RG fairing, the screws just thread into the plastic. The best thing you could do is fill the hole, re-drill and tap. Might be a good thing that they don't have captive nuts because if one of those broke loose and started spinning you would have one hell of a time getting that fairing off to replace it.
Old 02-12-2007, 05:12 PM
PhilM's Avatar
PhilM
PhilM is offline
SubZ is exactly correct!
Fill the the hole & drill it. Use the screw to start some threads. Then, GO EASY on those screws when ya tighten them down.
Old 02-12-2007, 05:46 PM
Phrogman's Avatar
Phrogman
Phrogman is offline
Nice to know that the fairings are that much different between a SG and a RG.
Old 02-12-2007, 06:24 PM
choochoo's Avatar
choochoo
choochoo is offline
Easy way remove gas cap, carry with you and find another bike it fits.......
but seriously.
re-fill the hole with any good quality epoxy glue (you mix two parts together to make)
Let set up and then drill a small pilot hole for the screw. this will allow easy re-insertion
of the screw and prevent breaking out (splitting)of the plastic.
Loctite also makes a stripped thread repair kit. mostly used for metal holes but will work
on plastic too.
Quick Reply: Stripped screw hole on my fairing..any ideas?
