Best way to tie bike down in an enclosed trailer?
Old 02-17-2013, 09:24 AM
cruzmisl's Avatar
cruzmisl
cruzmisl is offline
Default Best way to tie bike down in an enclosed trailer?
Title says it all I'm just trying to figure out the most secure way. Leave it on the side stand or keep it vertical. Best places to attach to the bike etc. What say you??
Thanks!
J.
Old 02-17-2013, 09:35 AM
Erik Palmer's Avatar
Erik Palmer
Erik Palmer is offline
ive always taken mine off the stand and used minimum of 3 straps. usually 4 for long distance
OldArmy's Avatar
OldArmy
OldArmy is offline
When I had a trailer I had tie downs in the floor. Stood them straight up, staggered front to rear, and tied them down. Also screwed down a couple of 2x4s padded with rug pieces on either side of the front tires. Since I had two bikes I went overkill and also time them off to each other and ran a few extras to the side rails too. Way overboard but nobody ever fell over. Did look like a demented spider web in there though.
Wedgeply (08-14-2020)
Old 02-17-2013, 09:43 AM
Flying Horse's Avatar
Flying Horse
Flying Horse is offline
Wheel chock with 4 quality tie-downs anchored 2 fore and 2 aft.
Old 02-17-2013, 09:50 AM
captsluggo's Avatar
captsluggo
captsluggo is offline
I consider it necessary to have the front wheel in a chock of some sort.
That requires it to be vertical or close to it. Ratcheting straps versus pull type, at least for the front. You don't want to bottom out the suspension, but I don't leave enough movement for hooks to come loose. A backup rope makes me feel better. For our race bike, we have a large rubber inflatable bladder that goes under the frame, it takes some of the load from the suspension and also provides some give.
Getting the tie down straps at a good angle helps too. And watch for all the other loose stuff in the trailer.
After a few miles of towing, recheck everything.
Captsluggo
Old 02-17-2013, 09:55 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,345 Likes on 3,279 Posts
I have the hooks from Kuryakyn and they work like a charm....i also tie the down tubes to be double safe.
Attached Thumbnails Best way to tie bike down in an enclosed trailer?-tiedowns.jpg
Gliden's Avatar
Gliden
Gliden is offline
Buy, rent, borrow a good front wheel chock for motorcycles and anchor that down first.
Get the bike in it.
Get 2 tiedowns pulling the bike toward (into) the wheel chock so it can't back out.
Get 4 more for front and rear left and right frame points. Drive nice.
Old 02-17-2013, 10:02 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
This is the best way.
Old 02-17-2013, 10:17 AM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,565 Likes on 1,497 Posts
I don't agree with the video showing how he pulls the rear back against the chock. You always want to pull forward towards the chock. To be real honest you don't even have to pull the rear forward,just don't pull against the front. Securing it side to side is fine too,just not rearward. I put two PowerTye big daddy's on the front and two PowerTye fat straps on the rear. I pull down and forward toward the front of the trailer and the chock. I have done this for years and not one problem.
Old 02-17-2013, 10:22 AM
crackercap's Avatar
crackercap
crackercap is offline
I use a large chock that is bolted to the floor. Then strap it to the floor tie downs, then one on each side of motorcycle in the upper tie downs on trailer. The condor chock or the one from HF works really well.
Quick Reply: Best way to tie bike down in an enclosed trailer?
