Best way to tie bike down in an enclosed trailer?
Old 02-17-2013, 10:27 AM
kennygsuperglide's Avatar
kennygsuperglide
kennygsuperglide is offline
I hook one strap to each side of the lower part of my bars crank them down to where the wheel can't hop. then throw one strap over my swing arm in the rear and done, (need good and secure eyelets in the floor). was taught to haul my dirtbikes this way as a kid, and use the same method for all bikes. I have hauled bikes almost the entire length of the east coast using this method and have never had one fall. I don't haul bikes as much as I used to but when I do I still use this method.
Old 02-17-2013, 10:33 AM
05RKCRider's Avatar
05RKCRider
05RKCRider is offline
Originally Posted by NDBadlands4-2
Pretty much covers it, the only things I did different was using a wheel locking type front chock so the bike would stay up-right after I got off to hook up straps & I took old crew socks with the toe cut off & slid them over the soft straps to protect the strap & chrome.
Now I'm retired I sold the trailer & ride everywhere I go as time is no longer a problem. All my straps & wheel chocks are now stored upstairs in my garage. Life is good.
Old 02-17-2013, 10:39 AM
RevRaz's Avatar
RevRaz
RevRaz is offline
You also don't want to pull forward in the rear because you lose stability. Directly straight would be best, and I think even rearward over forward would be preferred. The front straps will not let those rear straps pull the bike backward, just don't put ratchets in the back.
Originally Posted by Cowboy Rob
I don't agree with the video showing how he pulls the rear back against the chock. You always want to pull forward towards the chock. To be real honest you don't even have to pull the rear forward,just don't pull against the front. Securing it side to side is fine too,just not rearward. I put two PowerTye big daddy's on the front and two PowerTye fat straps on the rear. I pull down and forward toward the front of the trailer and the chock. I have done this for years and not one problem.
Old 02-17-2013, 11:22 AM
BB59's Avatar
BB59
BB59 is offline
I use a block of wood (4x6 or 6x6) under the frame/motor to help keep the bikes light on the suspension while trailering. The wheels are still on the trailer but when I ratchet it down I’m not completely collapsing the forks and rear shocks. I still use the 4 point tie down method but you don't have to collapse the suspension as much and it keeps the bike sitting very solid and level. I’m not a suspension expert but was told after having fork seals replaced on a couple of my dirt bikes that collapsing the front suspension and bouncing down the road is hell on seals.
Old 02-17-2013, 11:44 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,166 Likes on 5,391 Posts
Bud Light is necessary for proper tie-down
As far as straps...smart strap retractable , hands down...the loose end retracts into the tie down, once you use a set of these you will throw your other straps away...they sometimes have them at Wal-mart.
http://www.smartstraps.com/products/...tractable.aspx
Do yourself a favor and buy a fold-down chock for the trailer...you back out the bike, fold it down and you have a smooth floor...no unbolting or storing or tripping over it...I have used every type of chock made, and these are the least trouble.
http://www.powersportsplace.com/part...FQyDnQodbDEASg
Old 02-17-2013, 12:03 PM
buford's Avatar
buford
buford is offline
Also keep in mind that higher wheel chocks could may damage a rim on tire side wall if it rubs in any way. I always place an old towel into the chock to prevent this from happening. You don't want to pull away from the front chock with rear tie downs. The main reason for the rear tie down is to keep the bike from shifting from side to side when traveling.
Old 02-17-2013, 12:16 PM
bwana1's Avatar
bwana1
bwana1 is offline
Never leave it on the side stand, it will ruin the bushing.
NEVER have the aft straps pulling against the front straps. Every accel/decel of your vehicle causes the straps to stretch ever so lighty and if the straps a re working against each other it is increased.
Bwana
Old 02-17-2013, 01:03 PM
Wild Duck's Avatar
Wild Duck
Wild Duck is offline
Always trailer with jiffy stand UP.
Old 02-17-2013, 03:02 PM
WestPalmBop's Avatar
WestPalmBop
WestPalmBop is offline
Slickest setup i have ever seen. No more straps. 2 seconds and off you go!
http://ultimatemotorcycling.com/2012...trailer-mount/
Old 02-17-2013, 03:29 PM
Tom84FXST's Avatar
Tom84FXST
Quick Reply: Best way to tie bike down in an enclosed trailer?
