FXDXT Windshield/fairing Question
Old 02-13-2013, 10:23 AM
Ridewva's Avatar
Ridewva
Ridewva is offline
Default FXDXT Windshield/fairing Question
I am wondering how effective the FXDXT fairing is? Do you get much buffeting? Is the complete fairing and mount still available from HD or after market? I assume it would fit right on my 2004 FXDXI?
Early on I tried one of HD's detachable windshields and found the buffeting and noise unbearable so I never use it. It may be due to the location of the instruments that the shield is positioned be too vertical. Anyway I have on order a set of FXDXT saddlebags from LeatherPro and am just considering the pro and con of adding the fairing? Any words of wisdom?
Old 02-13-2013, 10:33 AM
Some_Punk's Avatar
Some_Punk
Some_Punk is offline
Awww ****, is the search button broken again?!?!
JK
In all seriousness, most of my buddies have T sport fairings on their scoots. They say it makes a difference, but idk to what extent. I rock a 18 inch windshield on my fairing, and I don't feel anything at freeway speeds (I'm also 6'6) Im assuming the T fairing would be similar, with a tall shield.
Old 02-13-2013, 10:41 AM
Guest
Guest
Posts: n/a
The Tsport fairing works well, I like mine. If you use a cut down windshield it will change the wind flow. Also, you would need the Tsport trees to mount it. Or just buy the Conelys replica.
Old 02-13-2013, 10:54 AM
Ridewva's Avatar
Ridewva
Ridewva is offline
JK
You're right, I had no idea this had been discussed so much. Meaning, since I didn't know, I *should* have searched. Anyway I just did and see it has been well covered so I'll get to looking through them.
I will look into Conely's replica too, thanks!
Old 02-13-2013, 12:38 PM
Some_Punk's Avatar
Some_Punk
Just trying to get a rise outta yah....
Old 02-13-2013, 04:17 PM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
A lot of how the fairing works depends on the seat you have, the height of the windshield on the fairing, and how tall you are. Mine works great for me, but it might not work for you.
Old 02-13-2013, 05:04 PM
Danofxdx's Avatar
Danofxdx
Danofxdx is offline
I like mine have has had the stock windshield and the winddeflector have an 11" windshield now it makes a huge difference
on eBay right now currently at $1200 with trees and everythingyou would need
http://www.ebay.com/itm/FXDXT-fairin...212c9a&vxp=mtr
Old 02-13-2013, 08:00 PM
El Rey's Avatar
El Rey
El Rey is offline
You can buy the fairing for an FXDXT, but not the actual moving parts for the windshield anymore.
The gears that move the windshield are prone to break and there are no replacements to be found.
Old 02-13-2013, 08:10 PM
_LostSoul_'s Avatar
_LostSoul_
_LostSoul_ is offline
The bezel is obsolete as well.
Old 02-13-2013, 08:31 PM
Ridewva's Avatar
Ridewva
Ridewva is offline
Thanks guys
I take it then none of the replica versions incorporate the moving aspect of the original? Was that function useful?
Quick Reply: FXDXT Windshield/fairing Question
