Neutral Safety Switch?
Old 02-12-2013, 03:45 PM
Ernst's Avatar
Ernst
Ernst is offline
Default Neutral Safety Switch?
I'm looking at new hand levers and I came across this review:
"...however the clutch lever is missing the tab to activate the neutral safety switch, which in my mind is a safety hazard. In other words, if a person stalls the bike, they cannot just pull the clutch lever to restart, they would have to put the bike in neutral first, start it, then back into gear...."
Is this correct? Hell, I don't even know if my bike has one (2013 Street Bob). I know I can start it while in first at a standstill with the lever in. I was under the impression a neutral safety switch just made you pull in the clutch lever to start the bike while it was in gear and if the clutch lever was not depressed then the bike had to be in neutral. I ALWAYS press the clutch lever down when starting my bike. The little green light has lied to people before...
Old 02-12-2013, 04:01 PM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
There's an interlock switch inside the clutch lever that allows you to start the bike in gear. When you pull the lever in it let's the switch complete the ignition circuit. There's another switch like that in the front brake lever for the brake light.
The clutch interlock is overridden when the bike is in neutral.
Old 02-12-2013, 04:02 PM
Campy Roadie
The tab on the lever pushes the switch to open the circuit when the lever is at rest.
Old 02-12-2013, 04:44 PM
roadster02's Avatar
roadster02
roadster02 is offline
Default What?
On Harley's?? When did this start?
Old 02-12-2013, 06:15 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
Ya not on my 2012 FXDWG. Just turn the switch and push th GO button.
Old 02-12-2013, 06:21 PM
DevilDawg1's Avatar
DevilDawg1
DevilDawg1 is offline
My 2012 FXDC has this feature. Most bikes manufactured after a given year (I dont know what year) have this feature. Some bikes will not crank in gear with the kickstand down.
In neutral, will crank without clutch.
In gear, have to pull the clutch or it will not do nothing.
I wish they all had the kick stand feature.
Old 02-12-2013, 06:22 PM
DevilDawg1's Avatar
DevilDawg1
Will you bike crank in gear without the clutch pulled in?
Old 02-12-2013, 06:27 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
I haven't tried that one. But my ricer wouldn't start in neutral unless the clutch was in.
Old 02-12-2013, 06:30 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
My WG has a kick stand feature. Just give her the gas and the kick stand pops right up. Lol
Old 02-12-2013, 06:55 PM
DevilDawg1's Avatar
DevilDawg1
Was the ricer a Suzuki?
Quick Reply: Neutral Safety Switch?
