SE Compensator upgrade, lots of metal
Old 01-30-2013, 01:53 PM
kipd's Avatar
kipd
kipd is offline
Default SE Compensator upgrade, lots of metal
I upgraded my noisy compensator to the SE version about 6000 miles ago on my 2010 SG. I changed the primary fluid today and noticed a lot of Metal shavings on the plug magnet. even more than the first change after the new bike break-in. Is this normal or should I be concerned? Bike is out of warranty and I really want to avoid the big bill after having the dealer tell me everything looks normal.
Old 01-30-2013, 02:27 PM
iclick's Avatar
iclick
iclick is offline
I would expect an above-average amount of small shavings the first oil change after installing the SE comp, but nothing big that would suggest something is breaking apart. I ran my bike a few weeks after the SE comp install and changed the fluid, expecting some contamination from break-in, and there indeed was some. Shavings have been reduced for subsequent changes, although after 25k miles I still get some. I would expect some shavings to show up between oil changes even in a well-broken-in primary.
Check after the next oil change and I'll bet you won't see as much contamination.
Old 02-04-2013, 10:52 PM
soft 02's Avatar
soft 02
soft 02 is offline
If you can wait a while the aftermarket is coming on board with an alternative to the SE comp.
Old 02-04-2013, 11:41 PM
piesik650's Avatar
piesik650
piesik650 is offline
I think the 124" and one of those need to meet for a date
Old 02-04-2013, 11:42 PM
soft 02's Avatar
soft 02
soft 02 is offline
Word is you will be able to get different cushion inserts depending on horspower output. Inserts will be like $30 i heard.
Old 02-04-2013, 11:46 PM
piesik650's Avatar
piesik650
I bet those are ALOT less clack clack clack sounding. **** you might forget you have a primary with that setup.
Old 02-04-2013, 11:48 PM
soft 02's Avatar
soft 02
soft 02 is offline
Here. I cut/pasted this from another forum. Good info. Cant wait.
https://www.hdforums.com/forum/gener...n-its-way.html
piesik650's Avatar
piesik650
thank you!
Old 02-05-2013, 02:00 AM
Expat1's Avatar
Expat1
Expat1 is offline
Location: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
This is good news.
The plastic inserts look like "PUR" (crosslinked polyurethane).
This material is extremely tough and has been used for many years to make disposable pavement scraping blades/lips on snow plows.
http://www.anchorrubber.com/specialt...low_blades.pdf
If the deformation chamber / volume in front of the damping material is well calculated this will last for ages.
Old 02-05-2013, 03:10 AM
mike5511's Avatar
mike5511
mike5511 is offline
This is good news! I've planned to change my comp, even though I apparently have a good one, when I changed my front pulley. Think I'll put that off for awhile until this new comp comes out.
Quick Reply: SE Compensator upgrade, lots of metal
