Starter is getting weak
05 flstc; 93k miles; upgraded to 95 about 20k miles ago;ever since last warranty work, (5k miles ago) the starter seems to be getting weaker and weaker. Battery is good as well as connections. Has anyone else had similar problems after having the upgrade? I did a cold compression check this morning and it was 125-130. All the visible drive components look good, (under primary cover).
thanks
thanks
