bendix jet #
Old 01-10-2013, 09:53 PM
redhead356's Avatar
redhead356
redhead356 is offline
Default bendix jet #
have adjustable mainjet bendix carb on my 73. as some of you know i have been having some problems with this carb. anyway newest prob-the main jet, bolt that holds on the float bowl broke at the base yesterday! when i bought the bike the float bowl bolt was really wrenched on tight,guessing it held on as long as it could..i can"t find a # on this thing anywhere. i know you can buy the kit,jet,needle,spring,o ring.i just need the jet,anyone tell me the # for this? thanks
Old 01-11-2013, 07:02 AM
IronMick's Avatar
IronMick
IronMick is offline
Try this website ... www.jetsRus.com
Old 01-11-2013, 11:06 AM
redhead356's Avatar
redhead356
thanks Mick. everything but Bendix on this site....... i can find the jets alot of places,just don't know which goes on the adjustable model.also if one for the non adjustable would work?they screw in the bowl too,just don't adjust on top
Old 01-11-2013, 01:43 PM
IronMick's Avatar
IronMick
IronMick is offline
I do not know about the Bendix.
I have an adjustable main jet kit for a Keihin butterfly-style carb. I believe that it has a standard 180 main jet, and has a mechanism to adjust the fuel flow down from that.
So it may be that yours just takes the largest jet available.
Might be more useful info here ...
ReBuilding the Bendix Carb
http://xlforum.net/vbportal/forums/s...d.php?t=941501
Bendix Carb
http://xlforum.net/vbportal/forums/s...d.php?t=596371
Setting the Bendix
http://xlforum.net/vbportal/forums/s....php?t=1294700
Rebuilded Bendix - now it's flooding..
Old 01-12-2013, 12:53 AM
piniongear's Avatar
piniongear
piniongear is offline
Was it the bolt that broke? The bolt that holds on the float bowl screws into what I call the 'main jet body' in this pic..........
Is the bolt broken off in this piece?
If not, then tell us which piece broke...........
pg
Old 01-13-2013, 01:15 AM
redhead356's Avatar
redhead356
it's the main jet that broke,#6 in the diagram. broke below the threads,where the holes are.
Old 01-13-2013, 10:00 AM
piniongear's Avatar
piniongear
Try Dennis Kirk for the part......
https://www.denniskirk.com/zenith
pg
Old 01-13-2013, 02:49 PM
ironhead tommy's Avatar
ironhead tommy
ironhead tommy is offline
Or it's time to update to a CV carb. Best way to go.. Good luck
Old 01-14-2013, 07:19 PM
scottfisher's Avatar
scottfisher
scottfisher is offline
I know you used to be able to get the jets on their own through the dealerships.
I would be surprised if you can get them like that now.
I would start by calling:
http://www.zenithfuelsystems.com/index.htm
and see what they can tell you.
s
62pan62
Exhaust System Topics
04-22-2009 03:35 AM
Tltrump
11-06-2006 09:58 PM
Tltrump
11-03-2006 08:01 PM
deuce31
04-04-2006 12:22 AM
Johneb48
10-23-2005 03:03 PM
Quick Reply: bendix jet #
