Woods 222 or Tman 555 torqster?
Old 01-09-2013, 02:11 AM
Anthony Vazquez's Avatar
Anthony Vazquez
Anthony Vazquez is offline
2nd Gear
Cool Woods 222 or Tman 555 torqster?
I own a 2012 street glide with a D D fat cat, Thundermaxx and Zippers hi flow air cleaner. Ride mostly one up back roads and the interstate I love the pull when you take off but want the cam that I pick to run out nicely on the high way. I usually run past 5000 rpms on the highway and dont think much about it at all. Will add lifters and of course pushroods to the build.
Not sure which would be the better bolt in choice? The woods 222 or the Tman 555 torqster. I am between the two.Opinions???
Old 01-09-2013, 05:10 AM
BatOuttaHell's Avatar
BatOuttaHell
BatOuttaHell is offline
I was considering the same two grinds and went with the 222. Should be arriving today. Sounds like our riding styles are similar. Don't know what your time frame to buy is...i won't have mine in for a couple weeks but will report back when i do. I don't think you can go wrong with either cam
Old 01-09-2013, 06:56 AM
Energy-Dude's Avatar
Energy-Dude
Energy-Dude is offline
Looking at the specs the tman cam has a power band slightly higher in the rpm. Very slightly, it is similar to the Andrews 57h.
Old 01-09-2013, 07:44 AM
Glockmeister's Avatar
Glockmeister
Glockmeister is offline
Woods 222 IMHO
Old 01-09-2013, 09:35 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
The TW -222 will definitely make an improvement over stock cams. I had the SE 255 cams in from day one and ran 10,000 miles one them, TW 222's made a night and day difference.
Old 01-09-2013, 09:52 AM
djl's Avatar
djl
djl is offline
Received 2,029 Likes on 1,498 Posts
I assume that you are referring to a shift point when you say "I usually run past 5000 rpms on the highway and dont think much about it at all". I don't think you can go wrong with either but the TMan 555 has a later intake close which will shift the power curve a bit to the right which would be more compatible with your riding style. Give up a bit on the low end but pick up a bit in the top end. JMHO, however, I have run three of TMans cams in bigger bore builds and must say that I am a fan.
Old 01-09-2013, 10:46 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
If ya are really running 5k+, I think ya ought to forget the 222 and at least add the andrews 57h and woods 555 to the list.
Old 01-09-2013, 10:54 AM
roadking2014's Avatar
roadking2014
roadking2014 is offline
I'm trying to figure it out too. when they describe the way the 222 works is by delaying the valve opening so it kinda creates more compression which is a great torque producing feature for lower rpm ranges. If I were shifting above 5000 rpm I dont think this would be my first choice on cams and if I had a high compression engine I think I would go to another cam too.
The good thing is that there are so many cams out there that you can just about buy one that is an exact match to your riding style, engine build and your wants.
jtp1984
05-26-2013 07:19 AM
Ryan8585
04-23-2013 12:54 PM
TedMan
Exhaust System Topics
17
07-26-2010 09:22 AM
HGM
EVO
21
01-15-2010 09:09 PM
HDF Tech
Engine Mechanical Topics
06-25-2005 12:59 AM
Quick Reply: Woods 222 or Tman 555 torqster?
