Screaming eagle compensator install
Old 01-02-2013, 10:32 AM
3itodd's Avatar
3itodd
3itodd is offline
Default Screaming eagle compensator install
I put a screamin eagle compensator on my bike over the weekend , it's so easy I thought I was doing something wrong! The hardest part was pulling off the old one because the strength of the magnet, but I just put 2 pairs of vice grips on the edges and it pulled right off ! Cya
Old 01-02-2013, 11:42 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
Thats good to hear, hows is it compared to the old one?
Old 01-02-2013, 11:56 AM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,434 Likes on 874 Posts
I assume you did a little grinding to the inner primary lip? Softails need a lot more material removed than touring models.
Old 01-20-2013, 01:46 PM
twism_23's Avatar
twism_23
twism_23 is offline
Yes, I would like to know if you ground it or removed your inner primary?
Old 01-20-2013, 04:18 PM
golfblues's Avatar
golfblues
If you are asking me I did the grind.
Old 01-20-2013, 04:51 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
yep, don't even need to remove the clutch pack
Old 01-22-2013, 09:03 AM
julesdain's Avatar
julesdain
julesdain is offline
I know that a few guys are doing this but I have to ask why? Is it an increase in performance, easier starts, less potential for a mechanical failure?
Old 01-22-2013, 09:26 AM
fat daddy's Avatar
fat daddy
fat daddy is offline
Imagine that and just think what the stealership would've told you about how difficult it is to change one and that's why they have to rape you at the cash register, congratulations to you.
Old 01-22-2013, 09:37 AM
golfblues's Avatar
golfblues
My 09 had a bad clunk at startup & a nasty one going into first. Neutral was a PITA. When I hit a bump or pothole the primary would make the clunk again. I opened it up & one of the bolt holes had a chunk missing from chain slap so I made the change. Now startup is smooth & quiet, first gear is a click, no more clunk over bumps & neutral is a breeze. I just added the Hayden tensioner too so we'll see how that works when it warms up some.
Old 01-22-2013, 09:39 AM
Jinks's Avatar
Jinks
Jinks is offline
Did the same recently, but I pulled the inner primary since I was changin' the bearing too. Not really any more difficult. Added the Hayden tensioner too. The change in sound went from a low howl to a chain sound. Bike even feels better, but that could just be my imagination......
Quick Reply: Screaming eagle compensator install
