Dyno graph with 57H cams in a 103?
Old 12-24-2012, 04:32 PM
Zener's Avatar
Zener
Zener is offline
Default Dyno graph with 57H cams in a 103?
I'm going to do cams in my 2012 Heritage and have spent quite a bit of time looking through the Dyno sections in the softail and touring forums. I haven't been able to find much with Andrews 57H cams in a new 103 that hasn't had a lot of other engine mods done to it. I'd like to see what the torque curve looks like in a 103 with those cams and only freer flowing exhaust and air cleaner. I'm particularly interested to see the range of 2000 to 3000 rpm. The new 103's are 6 speeds and I've found that even with a stage one done, I need to downshift twice before accelerating from around 60 mph and I'd really like to have a big improvement in this range. I'm also considering a Zippers 525. I've talked to guys at Andrews and Zippers and they aren't really very specific in their answers other than to trying to sell me one or the other. If anyone has a graph of what I'm looking for I'd appreciate seeing it. Thanks!
Old 12-25-2012, 05:31 AM
Weevil's Avatar
Weevil
Weevil is offline
Keeping in mind that many, many things will effect the final dyno results of any given build.
The build details:
2012 FLHX 103
SE A/C
Andrews 57H
V&H Power Duals
Kury Crusher Mellows
SE diaphragm spring for clutch
Stock heads
Gaterman GP-1023 lifters
SE Adjustable Pushrods
Attached Thumbnails Dyno graph with 57H cams in a 103?-dynosheets037.jpg   Dyno graph with 57H cams in a 103?-dynosheets038.jpg
Old 12-25-2012, 06:10 AM
Zener's Avatar
Zener
Zener is offline
DD&Weevil -- What is the difference in the two runs you posted? What type of tuner are you using (SE, PCV, Thundermax, etc.) Thanks for posting!
Old 12-25-2012, 08:46 AM
Weevil's Avatar
Weevil
Weevil is offline
Don't want to get too technical but one run is using SAE correction factors and one STD correction factors. The most "accepted" results are based on the SAE factors. If you really want to wade into the whole SAE vs STD stuff, just google it and you'll have plenty of dry reading ahead of you.
The tuner is a TTS Mastertuner. http://www.mastertune.net/
This is not my bike, If you want a good source of dyno's for different setups by some tuners around the USA willing to share information let me know. It also is a forum but keyed to more technical info vs who's the biggest poser stuff. (not that there's anything wrong in that)...
Old 12-25-2012, 11:57 AM
oct1949's Avatar
oct1949
oct1949 is offline
One is SAE and the other is SDT, which the STD usually net Higher numbers..
Old 12-25-2012, 12:10 PM
oct1949's Avatar
oct1949
oct1949 is offline
The build details:
2012 FLHX 103
SE A/C
Andrews 57H
V&H Power Duals
Stock heads
Really good looking lines with the 57's for the 103.. Son also went with the V&H 2-1-2s with S&S 551's on his 2010 Street Glide. thats a good set up also.
ONE other cam that fairly new is the woods 222's.. Fuel motor has done some testing with his pipes and tune and is also getting good numbers.
Might look at his web site and see if U like those also. FM has also posted a really good thread in her about the results he's getting from them.
Here I looked and found the link for Ya.. good read and he posted the sheets also.
Well worth looking through this thread.
https://www.hdforums.com/forum/fuel-...rformance.html
Old 12-25-2012, 12:16 PM
groovna's Avatar
groovna
groovna is offline
You might want to check out the new woods tw-222 cams. They are a torque cam. Check out some dyno charts on fuelmoto website with these.
Old 12-25-2012, 01:43 PM
satman's Avatar
satman
satman is offline
I am going to put 57h's in my 2012 FLTRX (Road Glide Custom) with SE aircleaner and Supertrapp 2 into 1 . I will use thundermax fly by wire tuner with this setup. I am wondering about replacing the .042 headgasket with a .030 one for about 9.9 to 1 compression - and when the heads are off cleaning up the ports where they match the intake manifold as well as the valve seats in the head. Or should I not bother? 100 ft lbs of torque at 2500 looks just awesome.
Old 10-16-2013, 08:00 PM
desertwolf's Avatar
desertwolf
desertwolf is offline
Andrews 57h are looking like a pretty good choice for an all around street cam.
Old 10-16-2013, 08:05 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
The build details:
2012 FLHX 103
SE A/C
Andrews 57H
V&H Power Duals
Stock heads
That is a very nice torque curve and some very respectable numbers...
Quick Reply: Dyno graph with 57H cams in a 103?
