Idles great but dies when you go to take off
Old 12-14-2012, 09:44 AM
lawdog150's Avatar
lawdog150
lawdog150 is offline
Default Idles great but dies when you go to take off
I just got a 91 Electra Glide that had set for 2 years. Cleaned carb and started right up. Idles great and it will take gas but when you put it in gear and go to take off it dies. Have took carb apart several times can't find anything wrong and it does the same thing. This is above my pay grade I am lost need held.
Old 12-14-2012, 09:51 AM
jimsflh's Avatar
jimsflh
jimsflh is offline
Petcock screen clogged? Fuel line clogged?
When you say it will take gas, do you mean you can rev the **** out of it and it runs fine?
Old 12-14-2012, 10:26 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,707 Likes on 1,343 Posts
What carb does this have? If the fuel line/filter is OK, then I'd say your intermediate and/or main jet is clogged.
Old 12-14-2012, 11:02 AM
lawdog150's Avatar
lawdog150
It has cv-40 carb. It will rev up and run fine but when you start to take off it dies. Took inline filter off still the same.
Old 12-14-2012, 11:16 AM
miacycles's Avatar
miacycles
miacycles is offline
Two things to check right off, if you have no vacuum leaks. First check the accelerator pump. When you twist the throttle there should be some fuel squirting into the carbs venturi. Secondly there is a little silver needle jet that sticks up into the venturi and the needle sticks into it. This piece has to be put in right or you can have the troubles you describe. One end has a radius on the inside and the other is square. The radiused end needs to be up so that the needle goes into that.
A few other possibilities: low float level, torn diaphragm on the slide, sticky slide, or carb still dirty or improperly assembled. Hope this helps.
John
Old 12-14-2012, 03:30 PM
j1mmy's Avatar
j1mmy
j1mmy is offline
when i was cleaning carbs almost daily at a shop, i still had to go back and reclean one 2-3 times sometimes. there are ports and passages built in to the carb body. some are only big enough to stick a single strand from a wire in to get clean.. the jets are only a small part of cleaning the carb.. plus everything mentioned above could be the problem.. a lot of people will clean the carb, but leave the metering needle dirty.. just some suggestions.
Old 12-14-2012, 07:16 PM
machinehed's Avatar
machinehed
machinehed is offline
Its probably carb. related but as dumb as this sounds ... have you rolled the bike in neutral to see if the brakes are stuck or something that is preventing the bike from moving .?
If all is well , try reving the motor past idle rpm and hold the brakes on to see if it dies under load as you describe.
Be carefull and let us know what you find.
lobofang
Shovelhead
11
07-01-2018 09:14 PM
Jlsher
11-05-2017 06:48 PM
RicRides
01-05-2015 11:11 AM
lagrato53
Carburetor Related
03-13-2014 06:31 AM
harleydwg555
Exhaust System Topics
05-14-2011 04:18 PM
Quick Reply: Idles great but dies when you go to take off
