Load equalizer
Old 12-13-2012, 05:51 PM
Boozr's Avatar
Boozr
Boozr is offline
Stage I
Default Load equalizer
Where does the load equalizer go and how hard is it to install on a 2012 street glide for led lights
Old 12-13-2012, 06:03 PM
Roger That's Avatar
Roger That
Roger That is offline
There is a 6 or 8 pin connector under the left side painted cover that is connected to the wiring harness that feeds the rear lighting. You need to disconnect that plug and insert the equalizer between the two. Very simple. Just pull directly outward on the side panel cover to remove with your hands. The cover has three plastic male pins that are inserted into rubber grommets.
Old 12-13-2012, 06:08 PM
Roger That's Avatar
Roger That
When you have the cover off the plug is off to the right in a kind of little indentation. You have to pull that plug and the wiring out a little to get your equalizer connected. Then just wire tie the equalizer off to the left and secure it. You are ready to go.
Did you get the Custom Dynamics LED's?
Old 12-13-2012, 06:36 PM
A5Firearms's Avatar
A5Firearms
A5Firearms is offline
What load equalizer are you guys using? Is it the Custom Dynamics one that is a direct plug in?
Old 12-13-2012, 06:42 PM
diesel6060's Avatar
diesel6060
diesel6060 is offline
I have led turn sigs on the back and want to add led turn sigs to the front. Does the load equalizer still go in line with the back sig plug or does it go somewhere else?
Old 12-13-2012, 06:43 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
The Biketronics is the plug 'n play one, does not require a power supply wire.
Easiest one I've seen, lifetime warranty, mounted by the battery on my '11RKC.
Old 12-13-2012, 06:51 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,922 Likes on 3,022 Posts
Any where it'll fit, ground one side and tap into the hot wire going to the light you want to add load to. The wires from the load equalizer can be extended.
Old 12-13-2012, 08:25 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
I have the Badlands eq and LED tail and signals all around.
Plug and play.
Old 12-13-2012, 08:49 PM
Roger That's Avatar
Roger That
I have the Custom Dynamics front dogeyz and rear led's with a load equalizer. All plug and play. Just one equalizer into the plug described. No codes and the signals match the indicator in timing.
Old 12-13-2012, 09:02 PM
limboglide's Avatar
limboglide
limboglide is offline
If adding LED turns front and rear, do you need two equalizers?
Quick Reply: Load equalizer
