screamin eagle oil pump
Old 12-12-2012, 12:05 AM
madhunter60's Avatar
madhunter60
madhunter60 is offline
Default screamin eagle oil pump
will a screamin eagle hi vol. oil pump work with the stock cam plate?
Old 12-12-2012, 07:20 AM
Rodzilla6's Avatar
Rodzilla6
Rodzilla6 is offline
Good question which I need the answer for also. Thinking of doing the cam chest and thinking of upgrading the pump while in there.
Old 12-12-2012, 07:22 AM
fwb35's Avatar
fwb35
fwb35 is offline
I do not believe so, The later cam plates and oil pumps were designed to work without an o-ring at the interface.
I just saw you have a 2010, am not sure about that, thought you had a early plate.
Old 12-12-2012, 07:49 AM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 70,402 Likes on 21,386 Posts
What's wrong with what you have now,or why do you think that you need a different oil pump?
Old 12-12-2012, 08:17 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
I don't have a clue, except, maybe the SE oil pump has more flow?
Not an SE pump, but I had a Feuling oil pump on my 07 FLSTF, the gyrator gears were much larger on that compared to the OEM pump. More flow helps to assist cooling.
Old 12-12-2012, 09:36 AM
madhunter60
my thinking is,more oil flow ,better cooling, and less pressure drop when running around the city, can't hurt with my 107 build.
Old 02-06-2013, 09:23 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
The pump from the 120r will fit right up to that 2010 plate
Old 02-06-2013, 11:11 AM
HOGBOY57's Avatar
HOGBOY57
HOGBOY57 is offline
i bought the kit which is the oil pump and cam plate. will be putting in when my new cam goes in 555tqster t-man. will be going in soon.
Old 02-06-2013, 05:34 PM
the warden's Avatar
the warden
the warden is offline
Higher flow does not necessarily mean cooler engine temps, in some cases the opposite. If the circulation is too fast the oil does not have adequate time to shed heat before it is circulated back from the oil tank to the cylinders.
Old 02-06-2013, 05:44 PM
BrownSanta's Avatar
BrownSanta
BrownSanta is offline
I was told by FM that I don't need to upgrade the camplate/oil pump for the 107 build
Exit45
Exhaust System Topics
09-15-2019 12:36 PM
sjbodie
09-04-2017 02:58 PM
sjbodie
Engine Mechanical Topics
03-24-2014 07:43 PM
t059736
Screamin Eagle CVO Models
10-03-2012 04:21 PM
electraglidenblue
07-16-2007 01:26 AM
Quick Reply: screamin eagle oil pump
