Woods 222 vs SE 255 in a 96"--HEAT ?
Old 12-04-2012, 07:42 PM
GEORGEW's Avatar
GEORGEW
GEORGEW is offline
Default Woods 222 vs SE 255 in a 96"--HEAT ?
Will the Woods 222 cam run COOLER in a 96" than a SE 255 cam?
Old 12-04-2012, 07:48 PM
pat1's Avatar
pat1
pat1 is offline
I had the 222's them in my bike and never noticed any extra heat. They ran perfect with the fuel moto tune. I have a set for sale if your interested
Old 12-05-2012, 01:46 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Yes, with a proper tune. The small overlap of the 255s makes heat. Might also look at 48h with stock compression.
Old 12-05-2012, 06:49 AM
dontdropit's Avatar
dontdropit
dontdropit is offline
I had 255's in a 2012 flhx and that was the coolest running bike I've owned. It was tuned with the sert. Not to say 222's wouldn't be cooler running because I really don't know. I believe 255's can be tuned to run without excessive heat.
Old 12-05-2012, 07:05 AM
fwb35's Avatar
fwb35
fwb35 is offline
The SE 255's are called a smog cam because they pass EPA and come stock in the CVO models, they are not much more then a stock cam, the intake duration is only 211 and the intake valve closes at 25 I think, very early so it makes torque early but will fall of after 4,000 rpm, plus the a overlap of only 13 will make more heat. I put in the SE 204,s, in my opinion a much better cam and pulls past 5,000 rpm, I tried different cams and like the SE 204's the best, if you are deciding between the 255 or 222 I would choose the 222, it is a very close cam compared to the SE 204.
Mikeduke108
08-10-2014 10:08 PM
0ldhippie
Exhaust System Topics
06-24-2013 09:54 PM
NPW
01-21-2013 09:23 AM
Buckinfitch
02-05-2012 10:43 PM
elpoman
02-17-2008 08:00 PM
Quick Reply: Woods 222 vs SE 255 in a 96"--HEAT ?
