Antenna relocation for Tour-Pack
Old 11-25-2012, 05:46 PM
ReilandLaw's Avatar
ReilandLaw
ReilandLaw is offline
Default Antenna relocation for Tour-Pack
My tour-pack finally came in and I installed it this morning, except I forgot about the antenna. I've seen several different types of relocation kits for moving the antenna - can you guys recommend one, or at least some of the pros/cons of the different kits?
Thanks,
Bill
Btw - here's a pic with the box installed -
Old 11-25-2012, 06:10 PM
racngrn's Avatar
racngrn
racngrn is offline
Best option (IMO) is to get the inner fairing mounted antenna. Keeps things nice and clean looking. Steve
Old 11-25-2012, 06:53 PM
ReilandLaw's Avatar
ReilandLaw
Thanks Steve - does it work well / get good reception ?
Bill
Old 11-25-2012, 06:58 PM
roaddr's Avatar
roaddr
roaddr is offline
Mine works real good.
Old 11-25-2012, 07:08 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
What I used on my Street Glide.
Old 11-25-2012, 09:26 PM
ReilandLaw's Avatar
ReilandLaw
All the wiring and crap inside the fairing kind of scares me - I'd hate to open up the fairing and then not be able to get all the wires stuffed back in. Wiring/electronics is probably my weakest area.
So, how difficult is it to install the inside-fairing antenna?
Thanks,
Bill
Old 11-25-2012, 11:11 PM
Buns79's Avatar
Buns79
Buns79 is offline
I bought one of the boom audio hidden antennas for my streetglide and the reception was about half that of the stock antenna I wasn't impressed, so this time when I took my tour pak off my 12 ultra I bought one of the 18.00 hidden ones on eBay and it works great! Install is simple remove the front of the fairing (there won't be any wires that you'll have to push back in other than pluging the headlight back in and then simply unplug old antenna and plug new one in and use the 3m tape to stick it to the inner fairing, your done now put fairing back on! Have fun!
Old 11-25-2012, 11:44 PM
funnythebunny's Avatar
funnythebunny
funnythebunny is offline
If you don't feel comfortable taking the fairing apart without risking a scratch, try something different:
Amazon Amazon
I used this 4.5" antenna on my 2011 F150 and looked so good that I bought them for my tour pack... they work very good, with little to no difference.
Old 11-26-2012, 07:24 AM
gvallanc's Avatar
gvallanc
gvallanc is offline
there is a very easy antenna relocation video under "DIY Mods and Trick to Save" secton. post #1150
I will be doing this one myself.
https://www.hdforums.com/forum/10575664-post1150.html
Hope this helps
nvsteve's Avatar
nvsteve
nvsteve is offline
Thanks,
Bill
It's easy. There are two unused wires you can use for a powered antenna.
I use the $20 Metra powered and it works well.
Quick Reply: Antenna relocation for Tour-Pack
