View Poll Results: A poll
HD primary oil #99887-84 (old style)
12.22%
Syn 3
14.06%
Amsoil
21.87%
Bel ray
2.50%
Rev tech
1.01%
Dyna cycle
0.22%
Redline
12.02%
Mobil 1
21.49%
Doesn't matter
3.07%
other
11.55%
Voters: 5049. You may not vote on this poll
What Primary Oil is your Choice
Old 08-10-2005, 03:13 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default What Primary Oil is your Choice
What oil WILL you be running (your preference), and not just what's in there now from the last service, possibly from the dealer service.
Old 08-11-2005, 12:20 PM
jcc/tx's Avatar
jcc/tx
jcc/tx is offline
Default RE: What Primary Oil is your Choice
Any 10/40 or 20/50 will do as, I'm sure. would ATS.
Old 08-11-2005, 12:23 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
>>>would ATS. Do you mean ATF? If so, that will also work, I believe Skip uses it in the primary. I prefer an oil instead myself JMO
Old 08-11-2005, 10:50 PM
jcc/tx's Avatar
jcc/tx
jcc/tx is offline
ORIGINAL: TCSTD
Yea; just messed up??????????
Old 08-12-2005, 01:32 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Thought you came up with something new!
Old 08-13-2005, 01:09 AM
wvrider's Avatar
wvrider
wvrider is offline
What is the best weight oil to use in the primary?
Old 08-14-2005, 01:11 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
ORIGINAL: wvrider
I run the HD primary oil after draining the syn 3 that came in the bike and I like the hookup on the clutch better with that oil. Otherwise it's 10/30 or 10/40
Old 09-15-2005, 06:21 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
I use ATF due to the best compatibility with clutch discs. anything will work though. lubrication and cooling of the clutch housing is job of the fluid and most any will do that.
Old 10-10-2005, 03:40 AM
HarleyWood's Avatar
HarleyWood
HarleyWood is offline
TC...
whats your opinion on synthetic ATF...is it worth the $$$...for use in the primary?
Thanks
Denny
Old 10-10-2005, 12:33 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Everyones opinion is different. I like the HD primary oil in there, I think it gives a bit more lubrication to the chain and sprockets myself. Some clutch packs recommend the atf for their chutches. Depends on what you're running for disks
Quick Reply: What Primary Oil is your Choice
