Lugging the engine
Old 10-27-2012, 11:33 PM
NJH's Avatar
NJH
NJH is offline
Default Lugging the engine
What does it do to the bike when you lug the engine?
Old 10-28-2012, 07:20 PM
00FattyT's Avatar
00FattyT
00FattyT is offline
I could be completely wrong here or miss some things but it is definitely hard on your clutch and can make your clutch start slipping prematurely and I would think that it can cause you to foul plugs and give you alot of carbon build up.
Old 10-28-2012, 07:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,499 Likes on 4,612 Posts
Lugging the engine makes the lower end bearings unhappy.
Old 10-28-2012, 07:53 PM
JustaHawg's Avatar
JustaHawg
JustaHawg is offline
I'm not a mechanic, but logically it would seem that lugging puts a lot of strain on all engine parts especially bearings. Because when you lug you're getting power mostly from the combustion and NOT the perpetual motion of the engine mainly the crankshaft. Just my 2 yen...
Old 10-29-2012, 12:11 AM
NJH's Avatar
NJH
NJH is offline
Is it equally as bad to shift gears at higher rpms?
Old 10-29-2012, 05:58 AM
Jondalar's Avatar
Jondalar
Jondalar is offline
We can do a virtual experiment to show how forces can act on the bearings, lifters, and pushrod surfaces. Pretend that we put our foot out and a car runs over the toe really fast. Now imagine the car running over the toe slowly. Slow is much worse.
Old 10-29-2012, 06:26 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,349 Likes on 3,281 Posts
All that plus is not where the engine is at it's best so why do it....It makes no sense....
Old 10-29-2012, 07:28 AM
NJH's Avatar
NJH
NJH is offline
Thank you all... I am a new rider and these tips are so helpful
Old 10-29-2012, 10:54 PM
Fastrider124's Avatar
Fastrider124
Fastrider124 is offline
Along with the extreme loads put on all bearings, especially the connecting rods, it can cause detonation and wear on almost every other part.
Shifting at higher rpms has much less chance of causing issues, unless you miss a shift, overreving the engine.
I never shift to next higher gear below 3000rpm unless coasting with no load.
The newer bikes have much taller gearing, most recommend not using 6th gear until 65-70 mph. If your coasting, the rpm can drop much lower, but you should shift down to get to at least 2800 rpm before trying to accelerate.
For passing, I would automatically shift back to 5th, unless I was already going 80, big gobs of throttle at low revs put huge strain on the motor, 6th being the hardest on everything. jm2c fwiw Fastrider124
Old 10-30-2012, 10:07 AM
grbrown's Avatar
grbrown
grbrown is offline
The answer to your question is that the engine will run at a uniform speed, when it is in its intended rev range. As engine speed drops, the crankshaft starts pulsing with each cylinder firing, so it is no longer running smoothly, but starts to jerk, or run erratically. That is when loads on bearings and other internal parts becomes excessive.
Be nice to your engine and change down if it starts doing that!
As for higher rpms, the engine has a rev limiter which prevents it over-revving, so no harm should be done by running it very fast. It will suddenly sound darned horrible and stop making power, but that is the protection system kicking in! Change up.....
Lunchboxx
Engine Mechanical Topics
03-02-2023 10:37 PM
Ron750
06-04-2019 01:15 PM
Huggerbugger
12-16-2017 02:19 PM
TravelingBiker
The General Motorcycle Forum
89
08-28-2012 05:58 AM
ironhead3fan
04-06-2008 07:13 PM
Quick Reply: Lugging the engine
