160 tire for 3" wide 16" rim
Old 10-24-2012, 07:30 PM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
Default 160 tire for 3" wide 16" rim
ok so i got a set of the 13 spoke mag rims with the 16" rim thats 3" wide. I know the Metzler 160/80/16 fits but there on backorder. my question is who else makes a tire that size that will fit? Avon has a tire that size but they say it only fits 3.5-4.5". will that fit on a 3" rim? its the same size tire so...
Old 10-24-2012, 07:44 PM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
So I tried to measure the rim and it looks like its 4" wide. But from what I've found online its 3" wide. Can anybody confirm what the rim size is?
Old 10-24-2012, 08:13 PM
8541hog's Avatar
8541hog
8541hog is offline
Are you measuring inside or outside dimension? Inside is the proper dimension.
A 3.5" rim is the smallest I would run a 160 on, not saying you will, but it is a possibility that in a hard curve a wide tire on too narrow of a wheel will roll off the bead, which could lead to catastrophe.
A 160 (6.3") is slightly more than double the width of a 3" wheel.
Old 10-24-2012, 08:19 PM
parts eeter's Avatar
parts eeter
parts eeter is offline
We got the Avon Venom 160 size mounted on a 3.5 and it looks great, not cupped up and all tread is still usable even on the chopper. I am gonna use the same tire on my FXDX mags ( 3.5 width) which is the same wheel you are speaking of.
Old 10-24-2012, 08:29 PM
07bobber's Avatar
07bobber
07bobber is offline
you can use the metzeler, avon, or dunlop 160/80/16 for the rear....i went with the metzeler thru rocky mtn atv .com they were in stock and have free 3 day shipping
Old 10-24-2012, 09:11 PM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
Alright guys thanks that's what I needed to know.
My cousin works at s dealership and they couldn't get the Metzeler cuz of back order. Ill check out rocky mt atv. If not looks like its the avons
Old 10-24-2012, 09:35 PM
07bobber's Avatar
07bobber
07bobber is offline
i tried getting the metzeler thru direct harley parts and they kept pushing the delivery date back because of backorder also so i decided to go somewhere that had it in stock
Old 10-24-2012, 10:28 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
A bit off topic, but...
I was running a 150 Metzeler and this last tire swap I changed to a 150 Avon Venom. The Metz was 5/16" wider than the new Avon is. My conclusion, I'll order a 160 Avon next round.
Old 10-24-2012, 10:30 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
Check out the Pirelli Night Dragons. They are made to fit Harley rims. They make a 180 for 16" rim. Pirelli owns Metzler.
Old 10-25-2012, 05:48 AM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
Good all with rocky mt atv! They had them in stock.
The shop my cousin works at, motorcycle superstore, bike bandit, & Dennis Kirk are all on back order for that tire!
Hessmonster
04-24-2015 03:08 PM
fergml
Wheels/Tires
02-15-2013 08:37 AM
blockzilla
09-07-2011 04:12 PM
St. Bob
09-07-2008 07:31 AM
Dino3981
12-09-2005 09:36 AM
Quick Reply: 160 tire for 3" wide 16" rim
