Normal Oil Consumption?
What do you guys feel is normal oil consumption? When I had my 2010 RK I never had to add oil in between changes. With my 2010 RG I always have to add oil. I took a 1600 mile trip the other week and find I'm down about a quart. I usually cruise at 70-75 mph, I don't redline the motor and I have 14,000 miles on the bike. Any thoughts on this?
I'm going down to the dealer tomorrow to talk to the service manager to get his input.
It's all over the place, from a quart for every 1,000 miles to no consumption in 5,000 miles. According to the Dealer, both are normal.(?)
I think it's the luck of the draw due to manufacturing tolerances, ( or lack thereof!)
I'm one of the lucky ones. 119,000 miles on the bike, ( heads were replaced at 67,000 to be fair,) and still no oil consumption between 5,000 mile services.
I ran Redline in the motor and after 2500 kilometers I found the level down and would need to add 1/4 of a litre.
Switched to Amsoil and ran the bike for 9000 kilometers on it and never had to add any in that span.
I think the oil you may use could have something to do with it. At least that's my experience.
Now for the price there are better options however it's not bad oil
I like Redline tranny oil but will not use the motor oil again.
I have a 2004 Heritage Classic with 25k miles on the clock. I've had it since it had 2k miles on the clock and it uses about a litre avery 1000 miles.
I also have a 2006 Screamin' Eagle Glide and it uses no oil at all between services.
Personally I think a quart/litre per 1000 miles is too much and it's a pain having to top up the oil so frequently. On the flip side, I guess the oil stays cleaner and the pistons/cylinders get more lubrication!
Neil
Neil
I've used the automotive 20w-50 in my bike with no consumption issues whatsoever. Sometime changing brands does help however don't write red line off due to an unconfirmed suspicion. In my experience they make an above average product. Well above any on the shelf mobil 1 product,and most oil manufacturers.
